sharookh Posted September 30, 2008 Share #1 Posted September 30, 2008 Advertisement (gone after registration) Does anyone know where I can see (which site) the 50mm Summicron f/2.0 with its lens shade extended? Is a separate lens shade available for this lens? Link to post Share on other sites More sharing options...
Advertisement Posted September 30, 2008 Posted September 30, 2008 Hi sharookh, Take a look here 50mm Summicron f/2.0 Lens shade. I'm sure you'll find what you were looking for!
andybarton Posted September 30, 2008 Share #2 Posted September 30, 2008 M or R? Link to post Share on other sites More sharing options...
sharookh Posted September 30, 2008 Author Share #3 Posted September 30, 2008 M or R? Andy - "M" Link to post Share on other sites More sharing options...
wizard Posted September 30, 2008 Share #4 Posted September 30, 2008 Is a separate lens shade available for this lens? No, at least not from Leica. You can screw the 2.8/50 Elmar's separate lens hood into the Summicron's filter thread, and it will extend exactly the same length as the Summicron's built-in hood in extended position, but since the diameter of the Elmar lens hood is smaller you are likely to get a small amount of vignetting in the extreme corners. Might not bother you if you are doing slides, as it will regularly be covered by the slide mount. Andy Link to post Share on other sites More sharing options...
Ivar B Posted September 30, 2008 Share #5 Posted September 30, 2008 Does anyone know where I can see (which site) the 50mm Summicron f/2.0 with its lens shade extended? Is a separate lens shade available for this lens? Which version of the M 2/50 are you referring to? Serial number? Link to post Share on other sites More sharing options...
ChadHahn Posted September 30, 2008 Share #6 Posted September 30, 2008 Here are some quick pictures of my 50/2 with the shade extended. Link to post Share on other sites More sharing options...
wizard Posted October 1, 2008 Share #7 Posted October 1, 2008 Advertisement (gone after registration) Which version of the M 2/50 are you referring to? Serial number? Ivar, he mentioned the extended lens shade. Thus, it can only be the latest version of this lens. Best regards, Andreas Link to post Share on other sites More sharing options...
sharookh Posted October 1, 2008 Author Share #8 Posted October 1, 2008 Ivar - As Andreas says - the latest version. Chad - I think you've cleared the confusion - Thanks a ton. Optically though , is the 50/2 equivalent to the 50/1.4 from f/2.0 onwards?? Link to post Share on other sites More sharing options...
Ivar B Posted October 2, 2008 Share #9 Posted October 2, 2008 Ivar - As Andreas says - the latest version. Chad - I think you've cleared the confusion - Thanks a ton. Optically though , is the 50/2 equivalent to the 50/1.4 from f/2.0 onwards?? Well, almost is perhaps the most correct answer, given that you refer to the 1.4/50 ASPH. The 1.4/50 ASPH is an extraordinarily good lens and nothing fully matches the performance of this lens, including the 2.0/50. For all practical purposes though, the latest version of the 2.0/50 is plenty good enough. Link to post Share on other sites More sharing options...
