some help please friends...
bobkatz
Hi Friends...Actually I have a M6 ttl 0.85, with a 50 mm. cron, and a 90 mm AApo cron. I really would like to have the lux 35mm but I cant afford it now :(. So Im thinking to buy a wide lens below the 35 mm, maybe zeiss or voigtlander (maybe 21mm or 25mm). So please tell me: which lens has the "leica Taste?, I must have too a viewfinder to atach on the hot shoe of my m6 Ttl 0.85 -Right? if so, which viewfinder I must consider?, and with the viewfinder attached is posible yet to use my flash sf 20?. And finally do you think is a good idea in a future to sell my cron 50mm and buy the lux 35 mm??:rolleyes:. Thanks very much in advance for yout time and opinions...:)
x
Your camera has a finder frame for the 35mm focal length, so no auxiliary finder is needed if that is what you want. As for the 'Leica taste', do you mean the old one, or the new one? One lens that would go well with the 50mm Summicron—having the 'old taste'—would be the version IV pre-aspheric 35mm Summicron. Do not be tempted by the previous, non-aspherical Summilux (vintage 1961) because the only excuse for that lens was its speed, and believe me, it was a bad excuse.
Voigtländer Cosina make good 35mm lenses, and good lenses in general. You may well consider buying one, but I suspect that sooner or later, you will come to regard is at a stop-gap. Zeiss, needless to say, make very good lenses. Any lens shorter than 35mm will of course require an auxiliary finder. It is rumoured that Leica will re-introduce its single focal length bright frame finders at the PhotoKina next month. Failing this, Voigtländer and Zeiss both make good finders of this type. Those by Zeiss are more luxurious, and expensive, but those by Voigtländer are perfectly serviceable.
With the excellent high speed films of today, very fast lenses are not as tempting as they were just ten or fifteen years ago. Speeds from 1:2.8 to 2.0 are quite satisfactory nowadays for nearly all purposes.
The old man from the Age of Tri-X
Actually, the old Summilux wasn't that bad at medium apertures. But you are after an ultra wide. Voigtländer 21 with rangefinder coupling is almost certainly the most economical choice, but I haven't had any experience with it. Voigtländer 25 does not have rangefinder coupling. My favorite is the Leica 24-ASPH. It's a superb lens, but pricey. Zeiss have a good reputation, and are priced somewhere between Leica and Voigtländer.
Voigtländer, Zeiss or Leica viewfinders are all good.
A Voigtländer double hotshoe adaptor will let you use both flash and viewfinder at the same time -- but you will need to attach the flash cable to the flash socket.
For detailed info and prices on all these products, see The Photo Village, Inc..
Guest leica_mage
None has either the 'new' ASPH taste, the older 'glow' (not all older Leitz had that, anyway) or the intermediate Mandler-at-the-edge-of-the-ASPH-precipice signature that the latest 50mm Summicron has. But for something very pleasing albeit different I would seriously consider the ZM (Zeiss) 25mm Biogon.
I seriously personally don't care for any of the CV lenses except the 15mm Heliar.
I'm afraid I'll have to disagree with Lars about both of the 35mm Leitz lenses he mentions. Personally I found that between f/2 and f/11 the pre-ASPH Summilux was one of the most magical lenses I've ever used, with an incredible gamut of delicious midtones. At f/2.8 already it is simply stellar. By comparison I found the Summicron (IV) a mediocrily uneventful lens - and at f/2 the Summilux's performance outclasses the Summicron (IV)'s in terms of contrast, resolution and resistance to flare and veiling glare. For this poster, it's no contest between the two (and I never used the f/1.4 stop, which indeed can be problematic), but do bear in mind that the Summilux's price has gone up rather steeply over the past three years - partly on account of posts like this one! :D
My one gripe with the Summilux was its 1 m minimum focusing distance - now there's a reason to hate a 35mm lens!
Cheers and happy hunting,
