M3 plus lenses
I was lucky enough to be given an M3 with a number of lenses by my photographer uncle who bought the camera direct from the factory. I haved taken some lovely pictures with the 21mm lens in the past. Unfortunately the equipment was stored in a damp cellar for some time (!) and I have just despatched the lot to CRR in Luton for an assessment.
I would be grateful if anyone can help with the provenance of the items. I have seen somewhere that the Summicron 50mm was Japanese-made for instance. Is this correct?
The light meter instructions are in French (my uncle lived in Paris) - does anyone know where I might find English instructions?
I would also be grateful if anyone knows the approximate market price for these items so that I can insure them correctly.
Finally, I am told that these lenses can be used with the M8. What effect is there on the focal length by mounting them on the M8? Does the 21mm become a 28mm equivalent?
Leica M3 739 972
Ernst Leitz Summicron 5cm f2 1215048
Ernst Leitz Super-angulon 21mm f4 1673161
Ernst Leitz Summaron 3.5cm f3.5 1176899
Ernst Leitz Elmar 90mm f4 1713778
Leitz 3.5cm viewfinder
Leitz 21mm viewfinder
Leicameter M 026354
Welcome to the forum, first of all !
The set you describe is a nice one : an M3 of the first series (M3s started at 700.000, yours is surely a "double stroke" model) and a good set of lenses, including a rather uncommon lens (the 21 f4) that is, in my opinion, a little jewel to have (even if not so good for pictures... 21 at that times was really an ultrawide... your item, that was based on a Schnedier design, shows a noticeable vignetting when used wide open). The other are all "good old" Leitz lenses, still today appreciable (and usable on M8 (*)), with the Summicron 50 that is REALLY good even to today's standards (of course, provided its glass is in good shape). Where did you read that the Summicron was made in Japan ? It's a complete absurdity.
If you like, post some pic of your set... here we all appreciate this kind of posts.
(*) With a little warning about the Summaron 35... on M8 it doesn't show the correct framelines, apart this, focuses perfectly.... given that you have an external VF for the 35 (SBLOO ?) I suppose it's of the kind without the "goggles"
Hi Luigi
many thanks for your welcome & prompt reply. You're quite right it is a double stroke model and without the preview level on the other side of the lens from the self timer.
I attach some photos...
Phil
You're lucky—that Summaron is the plain, goggles-less version that pros preferred, and there's a 35mm accessory finder for it! That Summaron would still rate a good 35mm lens today.
If the gear has escaped fungus (which is Death because all effective antifungal substances like thymol are so violently poisonous that they are prohibited) then after a CLA you will have a fascinating kit to experiment with.
Does the meter still work? It is a selenium-based model of course, a Leicameter MC, but basically, it works just like the later CdS versions, the Leicameter MR and MR-4. Set the camera to B. Rotate the knurled wheel on the meter to align the index line with the arrow on the housing. Press it in/up and lock it in its raised position with a slight turn, Slide the meter into the accessory shoe and rotate the knurled wheel so that it can fall with the little peg coupling with the slot in the shutter speed dial. The rest is pretty self-explanatory. An elementary hand meter is a good idea too. And with negative film, you don't have to meter every damn shot in any case—I don't do that even with my M8!
The old man from the Age of the M3
Leicameter M 026354
Hi Phil,
Welcome to the forum !
Have a look at Michael Butkus site
Leica meter M, instruction manual, user manual, PDF manual, free manuals
http://www.cameramanuals.org/leica_pdf/leica_meter_m.pdf
Hope this is some help
Kind regards
Ruben
Yes the light meter does work. I was perplexed by the opal diffuser but see now that it is used when measuring incident light (thanks for the link Ruben).
As for the lenses and fungus - I'll have to wait & see what CRR find! I'm intigued by the "goggles" reference Lars. Can you elucidate?
Yes. Both the 35mm 3.5 Summaron, the 2.8 Summaron and the 2.0 Summicron were also manufactured with a 'Suchervorsatz' which is often referred to as 'goggles'—it puts lenses before both the finder and the rangefinder windows which decrease the finder magnification (or rather, 'increases the minification') so that the field of view of a 35mm lens fits inside the standard 50mm frame. The solution is workable but a bit clumsy. Most pros did prefer the plain, goggle-less lenses and used them with a 35mm finder in the accessory shoe. Your uncle clearly did the same. Wise man.
One point to remember, and one that I have seldom heard mentioned, is that these early 35mm lenses do not bring up the 35mm finder frame on later cameras (M2 and later) that had 35mm frames (and the necessary, smaller 0.72x finder magnification to make space for them). The finder magnification of the M3 is 0.9x. A modern 35mm lens will bring up the 135mm frame on the M3, because 135 and 35mm lenses uses the same key position.
On the meter: After all these years it is a minor miracle that it is still working, but do not expect it to working at full power. You may be able to crank up the film speed so that it hands out more or less correct f-stops, but only with slow films. This is why I would recommend a hand meter. Later MR mteters CAN be used with zinc-air Wein cells, but they are indexed for the modern shutter speed sequence (e.g. 30–60–125 instead of 25–50–100 as on your M3) so they are not more convenient than a hand meter.
M3 ~$500, probably needs a $300 CLA
Assuming clean glass, no CLA required
21/4 ~$600, I bought one in LTM (no sign of grub screw marks) w/IWKOO hood for $1000
35/3.5 ~$250, I bought a 2.8 in LTM for $400
50/2 ~250, I bought and sold a black ver 3 for $300
90/4 ~$100-150, these go for low $$$
21 and 35 finders ~$250 each
Leica Super Angulon 21mm f4 Screw Mount  -  www.fotofixuk.co.uk
Edit: Added link
