Leica SF20 and SF24D
Annibale G.
x
When using the TTL mode on the M7, the flashes operate identically. The SF24 does come with a telephoto condenser attachment if you need that little bit of extra range. Both come with a wide angle diffuser for use with lenses wider than 35mm.
If you use the auto mode on the flash, the SF-24 offers 6 f-stops to choose from versus 3 for the SF-20.
If you think you might upgrade to the M8 in the future, the SF-24 is required for TTL operation with that camera.
I hope this helps.
Eric
