jc_braconi Posted May 23, 2008 Share #21  Posted May 23, 2008 Advertisement (gone after registration) JC: Is there any reason why these should be PMs? Why not share with all of us?  Guy   Yes, the process requires means which can wound or injure you seriously so I do not want to make the thing public. Link to post Share on other sites More sharing options...
Advertisement Posted May 23, 2008 Posted May 23, 2008 Hi jc_braconi, Take a look here Removing screw to M-adapter. I'm sure you'll find what you were looking for!
Philippe D. Posted May 23, 2008 Share #22 Â Posted May 23, 2008 Yes, the process requires means which can wound or injure you seriously so I do not want to make the thing public. Like oppening a bottle of Champagne. Â OK, JC is right, he could be sue for disclosure of a dangerous, but efficient, process. Oh jeez, that's hot. Link to post Share on other sites More sharing options...
luigi bertolotti Posted May 23, 2008 Share #23 Â Posted May 23, 2008 Yes, the process requires means which can wound or injure you seriously so I do not want to make the thing public. Â I can understand... I made a hand of mine cut & blooding years ago, thanks to an LTM adapter bayonet... Link to post Share on other sites More sharing options...
Gary B Posted May 24, 2008 Share #24  Posted May 24, 2008 Just found a minty Summicron collapsible. The first one I have had with absolutely no cleaning marks, no haze, no nothing. The barrel is beautiful too. That´s the good news. The little problem is that I can not remove the adapter and I want to use the lens on my LTM bodies. I have done this many times before with other lenses and it always works by mounting the lens on the (M) camera and then turning the lens in the right direction. But not this time.  Any tips/ideas?  Thanks, I used an all metal Leica ring (16469Y) when I did not want to use a body to remove an adapter from the rear of an older screw mt. lens Link to post Share on other sites More sharing options...
