Annibale G. Posted April 5, 2008 Share #1 Posted April 5, 2008 Advertisement (gone after registration) Hi, I can't find the Lithium 3 Volts DL 1/3 N batteries for my M7. A shop suggest me to put inside, instead of two of 3 Volts , four of 1,5 Volts. Is it possible? Dangerous? What do you suggest? Annibale Link to post Share on other sites More sharing options...
Advertisement Posted April 5, 2008 Posted April 5, 2008 Hi Annibale G., Take a look here M7 Batteries. I'm sure you'll find what you were looking for!
xjr Posted April 5, 2008 Share #2 Posted April 5, 2008 go google and type : http://www.watchbattey.co.uk Link to post Share on other sites More sharing options...
Annibale G. Posted April 5, 2008 Author Share #3 Posted April 5, 2008 oh well thanks . The problem is that I have inside the good ones but I'm leaving on Monday and I'd like to buy some spare ones. I bought 4 Silver 1,55 Volts ; Will them cause damage or problem to my camera if I need them? Thanks awfully. Annibale Link to post Share on other sites More sharing options...
kdemas Posted April 7, 2008 Share #4 Posted April 7, 2008 Yes, I have read you can use the 4. Not done it myself but I have seen repeatedly that others have. Kent Link to post Share on other sites More sharing options...
wizard Posted April 7, 2008 Share #5 Posted April 7, 2008 No problem to use four 1.55 V silver oxide cells instead of the two Lithium cells, but it is a little tricky to stuff those 4 cells into place. Andy Link to post Share on other sites More sharing options...
bill Posted April 7, 2008 Share #6 Posted April 7, 2008 No problem to use four 1.55 V silver oxide cells instead of the two Lithium cells, but it is a little tricky to stuff those 4 cells into place. Andy Quite. I did it once. It's a bit like trying to feed pills to a cat. Regards, Bill Link to post Share on other sites More sharing options...
JHAG Posted April 7, 2008 Share #7 Posted April 7, 2008 Advertisement (gone after registration) Hi,I can't find the Lithium 3 Volts DL 1/3 N batteries for my M7. A shop suggest me to put inside, instead of two of 3 Volts , four of 1,5 Volts. Is it possible? Dangerous? What do you suggest? Annibale I'm adverse to it. Several M7 users have reported less efficient contacts with that system to my Leica dealer. I did it once, had power cuts and never did it again. Link to post Share on other sites More sharing options...
petercs Posted April 7, 2008 Share #8 Posted April 7, 2008 Quite. I did it once. It's a bit like trying to feed pills to a cat. Regards, Bill I feed pills to my cat by wrapping them into liver sausages I think I cannot recommend that for batteries meant for the M7. Peter Link to post Share on other sites More sharing options...
