Annibale G. Posted March 15, 2008 Share #1 Â Posted March 15, 2008 Advertisement (gone after registration) I'm sorry, anyone know how much should be the development time for a Kodak Tri-X 400 pushed to 800 in ID-11 developer? Thanks awfully. Annibale Link to post Share on other sites More sharing options...
Advertisement Posted March 15, 2008 Posted March 15, 2008 Hi Annibale G., Take a look here Developing Tri-X 400 pushed to 800 in ID-11. I'm sure you'll find what you were looking for!
ejd Posted March 15, 2008 Share #2  Posted March 15, 2008 Annibale -- you can get some info from the massive development chart here: The Massive Dev Chart: B/W Film Development Times, Processing Data and more from the Ilford Photo web site here Welcome to the ILFORD PHOTO Website  Neither gives exactly what you want. The massive dev chart recommends 9.75 minutes for iso 400 and 13.25 minutes for iso 1600 using ID11 1+1 at 20 deg C. Perhaps mid-way between the two, 11 minutes, would be OK for iso 800.  Rgds, John Link to post Share on other sites More sharing options...
Mark Antony Posted March 15, 2008 Share #3 Â Posted March 15, 2008 Kodak states that with T-Max films that no increase in dev times is needed for a 1 stop push, here is the data sheet: Kodak B&W films PDF I have always understood D76 & ID11 to be pretty much the same so if you take the data from kodak for D76 you should be OK with ID11 for same times. Â The dev time I use for T-Max 400 is 8 mins in D76/ID11 that is the time I would use. Mark Link to post Share on other sites More sharing options...
Vieri Posted March 15, 2008 Share #4  Posted March 15, 2008 Kodak states that with T-Max films that no increase in dev times is needed for a 1 stop push, here is the data sheet:Kodak B&W films PDF I have always understood D76 & ID11 to be pretty much the same so if you take the data from kodak for D76 you should be OK with ID11 for same times.  The dev time I use for T-Max 400 is 8 mins in D76/ID11 that is the time I would use. Mark  Hey Mark, I think the OP was asking about Tri-X, not T-max. However, for the OP, Kodak literature is very good (though not as straightforward as Ilford's) for both - I suggest to give it a look, you might find what you need. Link to post Share on other sites More sharing options...
