jaapv Posted March 9, 2008 Share #1 Posted March 9, 2008 Advertisement (gone after registration) How do I put copyright info into the metadata automatically? In the camera? (M8, DMR) or in CS3? Link to post Share on other sites More sharing options...
Advertisement Posted March 9, 2008 Posted March 9, 2008 Hi jaapv, Take a look here Stupid question: . I'm sure you'll find what you were looking for!
cocker Posted March 9, 2008 Share #2 Posted March 9, 2008 How do I put copyright info into the metadata automatically? In the camera? (M8, DMR) or in CS3? Jaap, How do you import the files from the card? If you use Lightroom or CS3 there is a facility for automatically adding information to the Metadata. I imagine ther is with some other "import" programmes You can also do it to files that are already in the computer via CS3 Bridge. You can create a template via the Metadata panel in Bridge - click the little triangle and follow "create a template". Select all the files you want it to apply to and use "append Metadata". It will add the information in your template to the existing Metadata. Don't use "Replace Metadata" unless you want to wipe all other information! Link to post Share on other sites More sharing options...
jaapv Posted March 9, 2008 Author Share #3 Posted March 9, 2008 Thanks Keith. I understand I am setting a default or preference then in Bridge? Link to post Share on other sites More sharing options...
