wlaidlaw Posted January 18, 2008 Share #1 Posted January 18, 2008 Advertisement (gone after registration) I was looking today for an Editor for some EXIF data on some images I had taken. I found a neat, very simple piece of freeware that does it nicely. It is called Reveal 1.2 and is available here Album Shaper It does work on Leopard unlike some other programs we could name, although Leica UK says Solms are working on an update for Leica Digital Capture. Wilson Link to post Share on other sites More sharing options...
Advertisement Posted January 18, 2008 Posted January 18, 2008 Hi wlaidlaw, Take a look here EXIF editor for Macintosh. I'm sure you'll find what you were looking for!
Mauribix Posted January 18, 2008 Share #2 Posted January 18, 2008 Thanks Wilson, as soon as i get home i'll give it a spin! Best Regards Maurizio Link to post Share on other sites More sharing options...
spylaw4 Posted January 18, 2008 Share #3 Posted January 18, 2008 I suppose it depends on what you want to edit. I use Exif Renamer (donationware) to get rid of the camera's file name and substitute the date/time - have a look. It can be auto loaded via Image Capture which I find very handy! Link to post Share on other sites More sharing options...
wlaidlaw Posted January 18, 2008 Author Share #4 Posted January 18, 2008 I suppose it depends on what you want to edit. I use Exif Renamer (donationware) to get rid of the camera's file name and substitute the date/time - have a look. It can be auto loaded via Image Capture which I find very handy! Brian Capture 1-4 will do this automatically when you import if you want it to. What I wanted to do for a series of test photographs was to put the actual f stop and the focus distance. What it does not allow you do which I would also have liked was to put the actual name of the lens. I do not understand why the Firmware does not do this anyway as the M8 will know it from the 6 bit code (or anyway your designated lens if you are using a hand coded lens). I will look at Exif Renamer. Wilson Link to post Share on other sites More sharing options...
DavidStone Posted January 18, 2008 Share #5 Posted January 18, 2008 I tried Reveal, but it only seemed to like JPG's. And It doesn't seem to do the one thing that I want (and neither does any other software I've come across). I use an M8 with several uncoded lenses, both Leica and non-Leica. I want to add in the lens details in the blanks in the EXIF data, preferably at the DNG stage. Is this possible? And if so, how? David Link to post Share on other sites More sharing options...
wlaidlaw Posted January 18, 2008 Author Share #6 Posted January 18, 2008 I tried Reveal, but it only seemed to like JPG's. And It doesn't seem to do the one thing that I want (and neither does any other software I've come across). I use an M8 with several uncoded lenses, both Leica and non-Leica. I want to add in the lens details in the blanks in the EXIF data, preferably at the DNG stage. Is this possible? And if so, how? David Ahah - I had only tried JPEG's. I hope it will do TIFF's as well. I would not want to change the EXIF on any of my DNG's as they should be unchangeable. Wilson Link to post Share on other sites More sharing options...
echorec Posted January 19, 2008 Share #7 Posted January 19, 2008 Advertisement (gone after registration) Thanks for the link. The application works fine here but an excellent bonus would be to be able to record the lens name as you say. Link to post Share on other sites More sharing options...
R2-D2 Posted January 23, 2008 Share #8 Posted January 23, 2008 I tried Reveal, but it only seemed to like JPG's. Yes, the edit button is greyed out with TIFF files. And It doesn't seem to do the one thing that I want (and neither does any other software I've come across). I use an M8 with several uncoded lenses, both Leica and non-Leica. I want to add in the lens details in the blanks in the EXIF data, preferably at the DNG stage. Is this possible? And if so, how? You might try ExifTool: $ exiftool -FocalLength=75 eagle.dng Warning: [minor] Possibly incorrect maker notes offsets (fix by 2314?) - eagle.dng 1 image files updated If I only had the time to write a front end... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/43017-exif-editor-for-macintosh/?do=findComment&comment=459903'>More sharing options...
DavidStone Posted January 23, 2008 Share #9 Posted January 23, 2008 Well, I agree that ExifTool looks promising. If only I knew what a terminal window was I could probably make a go of it. I'm using an Intel Mac and OS10.4.11. David Link to post Share on other sites More sharing options...
wlaidlaw Posted January 23, 2008 Author Share #10 Posted January 23, 2008 Well, I agree that ExifTool looks promising. If only I knew what a terminal window was I could probably make a go of it. I'm using an Intel Mac and OS10.4.11. David David, Terminal window is the red button marked "DESTRUCT" for your Mac. Seriously it has its uses, like I was using Traceroute and Ping last week to analyse a slow running broadband connection via Airport but you can do horrible things if you are not very careful. Wilson Link to post Share on other sites More sharing options...
R2-D2 Posted January 23, 2008 Share #11 Posted January 23, 2008 Well, I agree that ExifTool looks promising. If only I knew what a terminal window was I could probably make a go of it. I'm using an Intel Mac and OS10.4.11. ExifTool runs on PPC and Intel Macs - the installation is easy: Installing ExifTool. Link to post Share on other sites More sharing options...
DavidStone Posted January 24, 2008 Share #12 Posted January 24, 2008 ExifTool runs on PPC and Intel Macs - the installation is easy: Installing ExifTool. Yeah, well, easy and easy. This is probably the wrong forum for this kind of stuff, but in the hope that there are dummies like me lurking out there hoping that I will display my ignorance to help them out too, here goes: I've got this far and I'm a bit reluctant to go further. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/43017-exif-editor-for-macintosh/?do=findComment&comment=460647'>More sharing options...
R2-D2 Posted January 24, 2008 Share #13 Posted January 24, 2008 Yeah, well, easy and easy. As a former BOfH it's even "easy" with a tar ball... ;-) Just take the disk Image: OS X Package Download the ExifTool OS X Package from the ExifTool home page. (The file you download will have a name like "ExifTool-#.##.dmg".) Install as a normal OS X package. (Open the disk image, double-click on the install package, and follow the instructions.) You can now run exiftool by typing "exiftool" in a Terminal window. I've got this far and I'm a bit reluctant to go further. As long as you don't "read mail, really fast" (aka "rm -rf") it's OK. Just kidding, here's the package you need: http://www.sno.phy.queensu.ca/~phil/exiftool/ExifTool-7.13.dmg. Link to post Share on other sites More sharing options...
