I haven't been able to find a source that shows Leica lens serial numbers below 100,000 (like https://wiki.l-camera-forum.com/leica-wiki.en/index.php/Serial_Number_Links_for_Leica_Cameras_and_Lenses). For instance I have an Elmar 90mm f/4 with S/N 96771 which I can't find any info on. Does such a resource exist?
Hi @bruceb
I'm not entirely sure what specific information you need, but I have conducted some research on 9cm lenses from that period, which you can read using the link below:
https://www.summichronica.com/screw-mount-lenses-90mm
The first 9cm f/4 Elmar lens to have a serial number was number 94092 from 1931, as per Helmut Lagler's "Phänomen Leica: Eine Analyse, LEICA Literatur-Handbuch 1924-2020" book.
Also, I would be happy to consult the literature available to me if you have a specific question in mind.
I hope this helps.
Edited by Dr Monochrom
9 hours ago, Jul said:
According to Hartmut Thiele , 96771 is a 9cm f4 Elmar from a batch of 532 from 1931/32 . Thiele's lists commence at 92201. The information from that period is very sketchy and difficult to assess. Try info@leica-camera.com , but I suspect you will not get any more information. Is there a particular detail you are looking for?
William
Thiele (Grosses Fabrikationsbuch Leica Objektive) has a list starting with 92201. I found however Elmars 5cm with  nuubers is the range 71xxx. I believe Leica srated to assign own number to the lenses after introducing  IC non standard, with IA lens was fully associated to the the camera. The lowest number that I found was 71973, lens was on IA. These early numbers were however not on the front ring, not visible from outside, you have to take optics out of the mount to see it. There was a period of time when IC and IA were produced in paraller and this is an explanation for the Elmars on late IA having as well own serial number.
In 1945/46 some 5 digits lenses were delivered to US Army, previously unused number have been taken.
Edited by jerzy
Thanks, Jerzy, I have seen some of those early numbers. The reason for this is that up to a certain point the lens was not interchangeable and effectively it had the same number as the camera. Once lenses became interchangeable they initially started to have either full camera number or the last 3 digits of the camera serial number engraved on the side as they still had to be matched with the camera. Earlier conversions in Britain from 1929 onwards, using Dallmeyer lenses, had the full camera serial number and the lens serial number engraved beside one another on the lens barrel. Once the standardised interchangeable lenses with a 0 engraved on the side for fitting on standardised cameras with a 0 on the lens mount were introduced around 1931, then lenses began to have a life of their own with their own serial numbers. Thiele's list begins at around that time. I am trying here to explain the 'why' as regards serial numbers in that period. It is partly a question of records, but it is more significantly a change in the nature of the products being manufactured in Wetzlar.
For what it is worth, I own the fifth ever Leica made in Wetzlar with an interchangeable lens. It was delivered on 16th April 1930 with the serial number 37284 and the number 284 is engraved on the side of the lens, which carries no other serial number. I also own 14225 a I Model A from 1929 which was modified by Sinclair in London to take a Dallmeyer 4 inch lens with an interchangeable mount. That has both serial numbers camera 14225 and lens 145778 on the side of the lens, camera and lens both have 33mm mounts, not the later 39mm. The Sinclair conversions commenced before Leitz started its practice of engraving camera serial numbers on the barrels of matched lenses. All of these changes occurred over a very short period of time.
William
