I had to open my 135er Hektor because 3 aperture blades where out of place.
After rearranging, cleaning, and lubricating the head everything works fine.
Now it bothers me that the focus doesn't work as well as it could.
Before I take the try and error way to reloube it I ask here in the
forum for a little help.
Thanks for every tip
separate (unscrew) distance scale and riffled tube, you will be able then to unscrew the whole helicoid, Mind the point when threads will separate. Additionally, in next step you might want to remove the riffled tube - remove head, pull off the marked ring, remove 3 screws that are under the ring
