jg1976 Posted 6 hours ago Share #1  Posted 6 hours ago (edited) Advertisement (gone after registration) Anyone with experience regarding image quality?  I am mainly shooting in studio, once a while outside with organized flash and weight & size of the camera is no issue for me. Edited 6 hours ago by jg1976 Link to post Share on other sites More sharing options...
Advertisement Posted 6 hours ago Posted 6 hours ago Hi jg1976, Take a look here should I leave my S007 for SL3?. I'm sure you'll find what you were looking for!
helged Posted 5 hours ago Share #2  Posted 5 hours ago 34 minutes ago, jg1976 said: Anyone with experience regarding image quality?  I am mainly shooting in studio, once a while outside with organized flash and weight & size of the camera is no issue for me. SL3 with L-mount lenses, I presume. If so, lot's of options exist, from the absolute optical superiority, to all sorts of 'imperfect' (and often interesting) renderings. AF is much, much improved compared to S. And you have IBIS on SL3. And tilted back screen. SL3 with S-mount lenses work fine, in my case mostly in manual focus mode, with image magnification activated (if time and subject allow). S-lens AF on SL3 is slow, no significant improvement. Re sensor: I find the S-files easier to work with in post-processing. Plus the S-lenses have a - for my eyes - a beautiful rendering. 1 Link to post Share on other sites More sharing options...
John McMaster Posted 4 hours ago Share #3  Posted 4 hours ago If you are studio based, or outside flash (presumably with CS lenses) what does the SL3 offer? Different lenses, higher MP, better AF but better overall image quality? john Link to post Share on other sites More sharing options...
jg1976 Posted 4 hours ago Author Share #4 Â Posted 4 hours ago It's a shame medium format is disappearing from Leica. As I have experienced it is superior, but I could be wrong. It is over 60mp on SL3 and 37.5mp on Leica S007. My real question is how these compare in image quality, where one is also medium format. Link to post Share on other sites More sharing options...
otto.f Posted 3 hours ago Share #5  Posted 3 hours ago I would not leave the S for an SL which still  remains an SL, even the third.  The only thing you get more is digital über-sharpness. More pixels on a relatively small sensor gives not necessarily a nicer image. That's just my opinion and the way I see the images here on LUF. E.g. the M11M images are less nice in my view than those from the M9M. But, as suggested above,  which instrument is the best for which work? The S is not the best choice for sports or wildlife. 2 Link to post Share on other sites More sharing options...
Pieter12 Posted 3 hours ago Share #6 Â Posted 3 hours ago I wouldn't in your circumstances. Everything you do works in the S favor. 1 Link to post Share on other sites More sharing options...
jg1976 Posted 2 hours ago Author Share #7 Â Posted 2 hours ago Advertisement (gone after registration) Thanks for all the feedback! I would cry tears of joy over abandoning my S medium format, for a smaller sensor. I've considered the S3, but I feel that Leica is removing more and more service as more lenses are discontinued. So, considering future-proofing, I should probably switch, but my S heart says no... Link to post Share on other sites More sharing options...
Stuart Richardson Posted 51 minutes ago Share #8  Posted 51 minutes ago I think you would need to define what characteristics of image quality you are after. If it is edge to edge sharpness, resolution and the hit rate of getting a properly focused, stable and sharp image, then the SL3 will be better. If it is dynamic range and a medium format look, then it will likely be the S007. It's really a decision you would need to make for yourself within your own workflow. If you are fully satisfied with the S007 now, then it doesn't really sound to me like you would need to change. If anything, probably better to wait another two years if you can. By then it should be clear whether Leica intends to continue the S system in a mirrorless form, or whether it is gone for good. There are of course other medium format options too, like the GFX and Hasselblad that exist now and are medium format. 1 Link to post Share on other sites More sharing options...
LeicaR10 Posted 3 minutes ago Share #9 Â Posted 3 minutes ago (edited) jg1976, Â My thoughts for your angst over the S007, might help you. Â I owned and used the S system and all models for 15 years. Â There is nothing that comes close to the rendering of the camera and certainly the most excellent S lenses. Â You might recall the S lenses need no firmware correction and render in a most incredible cinematic way. Â My clients who were very selective (picky) told me time and again, they would not buy my landscapes unless I used the S system. Â Over the many years, I did very well financially with using just that system. Â IMO, you have a S007 that works, along with S lenses that work too. Â The S3 bodies are coming down in price, many are in mint condition. Â I suggest you keep using what you have and create masterpiece images that only the S camera and lenses can help you create. Â Both Stuart and Otto.f are IMO, quite spot on too. Â Last, I can assure you the S4 system is on its way as mentioned during several interviews with Leica company seniors and your S lenses will not be obsolete. Â I suggest both patience and creating most excellent S system photographs might well serve you better until the S4 arrives. Â Just my two cents. Â r/ Mark Edited 3 minutes ago by LeicaR10 Link to post Share on other sites More sharing options...
