On 11/16/2025 at 2:25 PM, TomB_tx said:
the M7 as the ideal companion to the M10.
How's the current situation on m7 shutters being repairable? I always avoided one because I don't want to spend 3k on a film camera that's going to die with no solutions, in theory it would be my ideal film m.
Btw OP I routinely use a m4 and a m4-2 and if one doesn't need ttl metering they still are perfectly reliable cameras for quite a bit less money than a new m6. The m4 tbh looks better built too.
Edited by Bliz
Am 19.11.2025 um 16:35 schrieb Don Flynn:
I'm the biggest fan of the M5 you'll find but I would not suggest getting 1 as a 1st or only Leica film camera. The reason is as mentioned, spare parts are scarce and finding a repair tech willing to work on 1 and knowing what they're doing is damn near impossible in 2025,
If your wanting a "older" M series Leica I would look at the M4-2 or M4P. The later is basically a M6 without the meter, and both are fine cameras. They tend to cost less than the M4 because they were made in Canada and Leica "snobs" prefer German made ones
German guy here, I got a CLA'd M4-P this year and it's wonderful (and beautiful). I'd say it is the best one can get for reasonable money.
That's purdy 😁
Well, the M7 was produced from 2002 to 2018, so they are "newer" than other models. I don't know Leica's stand on servicing them now, but the electronics should still be holding up well. The shutter curtains are released by electromagnets, and I hear of issues when they weren't aligned accurately, and also ferrous particles can be attracted and build up. Mine was made in 2014 and still seems like new. The frame line masks were sticking when I got it, which DAG said was common in Ms of the 21st century. He fixed mine quickly and it's been fine. I don't worry about it - it may well outlast me. I tend to use it more than my 2 M6.
Isn't there a practice to repair such goods for 10 years after production ceases? That would be until 2028.
Edited by TomB_tx
56 minutes ago, jacopastorius said:
Do I have to look into the rangefinder viewfinder to focus and then into the voigtlander to compose the shot?
Yes, no external vf is rangefinder coupled. Usually for very wide lenses (under 24mm) it doesn't make much of a difference tbh. I zonefocus 21 and 15 with no problem. What I don't love about voigtlander external viewfinders is that the hotshoe isn't really aligned with the lens on the camera, so with ultrawides (21 or less) composition can be a bit of a guess and it's easy to experience bent lines that you didn't thought were there.
My Leica 21mm is slightly offset compared to the hotshoe, it still doesn't really align with the lens but it's not as off as the voigtlander 15 and 25 I have.
Edited by Bliz
Thank you for this feedback, this should be a problem. So what viewfinder do you suggest?
There are a lot of people that don't find it annoying though. For 21 that is my most used wide, I bought a second hand leica 21mm brightline viewfinder like the one in the picture.
Btw imo the Voigtlander ones are brighter and nicer to look through, but still...
Edited by Bliz
Do you think the fact that is not aligned with the lens can be corrected like the parallax error by tilting a bit the camera to the left?
You can reframe, I don’t find it easy with super wides though, a small movement gives a big difference. I had better luck using the hotshoe finder to understand what’s going to be in the frame but then shooting through the camera finder because it’s parallax correct.
At this point you’re reading my personal gripes with superwides on rangefinders though 😅
Edited by Bliz
