ivancook Posted 13 hours ago Share #1  Posted 13 hours ago Advertisement (gone after registration) I have an M11 that I recently purchased used and a brand new 35mm Summilux Close Focus. Rangefinder patch seems to be dead on at infinity (from looking at stars and the moon) and actual photos are extremely sharp at infinity. Also, rangefinder patch and actual focus seem perfect at mid distance. The issue is when shooting around .7m the actual area that is in focus is about 2" in front of where the rangefinder shows focus. For example, in the attached image I shot at about 45 degrees to the ruler and the rangefinder patch shows focus at 15" but actual focus is closer to 17.5". Unfortunately, I have no other lens to test. Is this just to be expected given the mechanical nature of the rangefinder and the narrow DOF at 1.4 or does it need calibration? I'm fairly handy, and I've read through prior guidance on here about calibrating the rangefinder. Hoping to get a bit of feedback before diving in. If the infinity adjustment is almost imperceptibly off in the rangefinder patch, could that yield these sorts of results at close focus or is this more likely to require adjustment of the arm length as well? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/425280-front-focusing-feedback-needed/?do=findComment&comment=5889817'>More sharing options...
Advertisement Posted 13 hours ago Posted 13 hours ago Hi ivancook, Take a look here Front focusing - feedback needed. I'm sure you'll find what you were looking for!
Derbyshire Man Posted 8 hours ago Share #2 Â Posted 8 hours ago New or used? Link to post Share on other sites More sharing options...
JNK100 Posted 5 hours ago Share #3  Posted 5 hours ago (edited) 3 hours ago, Derbyshire Man said: New or used? Lens is new and camera used Edited 5 hours ago by JNK100 Link to post Share on other sites More sharing options...
ivancook Posted 3 hours ago Author Share #4  Posted 3 hours ago 4 hours ago, Derbyshire Man said: New or used? Lens is new and camera is used but shows no sign of damage or prior adjustment. Link to post Share on other sites More sharing options...
ivancook Posted 3 hours ago Author Share #5 Â Posted 3 hours ago Looking at the moon again this morning and if anything focus might be stopping just a hair early of perfect alignment in the patch. Could that equate to a few inches off up close? Link to post Share on other sites More sharing options...
jaapv Posted 3 hours ago Share #6 Â Posted 3 hours ago No. It is more likely that the shims of the FLE group are out of tolerance. Link to post Share on other sites More sharing options...
Derbyshire Man Posted 2 hours ago Share #7 Â Posted 2 hours ago Advertisement (gone after registration) Where are you based Ivan? Link to post Share on other sites More sharing options...
ivancook Posted 2 hours ago Author Share #8 Â Posted 2 hours ago 3 minutes ago, Derbyshire Man said: Where are you based Ivan? Texas, USA Link to post Share on other sites More sharing options...
Derbyshire Man Posted 2 hours ago Share #9  Posted 2 hours ago Tricky. I’d head to the nearest shop with some more lenses to see if you can get a feel for which half is the problem. 1 Link to post Share on other sites More sharing options...
ivancook Posted 1 hour ago Author Share #10 Â Posted 1 hour ago Am I correct in assuming that adjusting the infinity point in the rangefinder only impacts the view in the rangefinder patch, and not actual infinity focus from the lens? Link to post Share on other sites More sharing options...
