Polarising Filter
huwge
i'm also in the process of putting together step-up adapters and polarizers for my m8 set. current thinking, based on input from several threads and magazines:
1) i bought an inexpensive linear polarizer to hold in my hand, and plan to "calibrate" it with the polarizing filters for each lens by placing a marker (white paint?) on the filter rims to indicate maximum effect. in practice, turn the handheld filter to the desired angle/effect (10 o'clock etc), then turn the filter on the lens to the same position. a bit cumbersome, but accurate?
2) the leica WATE filter holder currently advertised in the forum classified ads has two cutouts. maybe it's possible to bore 1-2 holes in a step-up adapter so that the polarizing effect can be seen while focusing through the rangefinder?
anyhow, good luck!
rick
anyhow, good luck!
rick
Maybe I misunderstood You, but why don't You as I described above:
1) Put the Polarizer (ES77) with the Heliopan adapter on Your camera.
2) Find Your motive.
3) Lift the camera a bit so You can see through the holes in the Polarizer (it's diameter of 77 allows for this at least on an MP)
4) Turn the Polarizer until maximum effect.
5) Move the camera to Your eye and take the picture.
No need for fancy "extra"equipment in the hotshoe or in Your hand
hello kasimir
thanks for your input. i didn't know about the heliopan step-up adapters with holes when i first wrote, but they sound like a good solution. i also have some 72 and 77mm filters left over from dslr days.
kind regards
rick
Leicagoodies have them in a complete set (from Heliopan) for most R.F. cameras.
www.leicagoodies.com ==> STEPS
Here you can also see the pictures when fitted on the M camera.
A pretty nice solution.
I am using the Leica View nr. 381 (Heliopan) 77/55mm
Then the step up nr. 194 55/46mm (for the Elmarit 2,8/28mm and my new Summarit 2,5/75mm) and if necessary the step up nr. 245 46/39mm for the Summicron 2,0/50mm.
Using the Heliopan polarizer SH-PMC circular ES77 (Also for Canon prof. L- lenses) it's a perfect combination.
