Fotomman Posted 2 hours ago Share #1 Posted 2 hours ago Advertisement (gone after registration) I have recently bought a black Leica 1A with a long lens pin fixing the lens to the body in the 11 o’clock position. As seen in the example attached (not my camera) the long pic is cutaway neatly in half like mine. Most 1A Leicas have a shorter pin. Why is my pin longer? The lens on my camera is marked in feet with a close-focus of 1.5 feet. I suspect the longer pin is necessary to stop the rotation of the lens as it is unscrewed to the closest focus setting of 1.5 ft? On my 1A the cut-out allows me to attach the lens cap when the lens is fully retracted. Is this a factory spec? I have seen reports that Ogilvy & Co, the London advertising and marketing company imported a batch of close focusing Leica 1A cameras around 1930-ish? Anyone know their serial numbers? Francis Ogilvy, brother of David Ogilvy, the advertising guru, purchased Leica No. 225 for the company, the first Leica to be imported into the UK. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/425118-leica-1a-stop-pin/?do=findComment&comment=5884904'>More sharing options...
Advertisement Posted 2 hours ago Posted 2 hours ago Hi Fotomman, Take a look here Leica 1A stop pin. I'm sure you'll find what you were looking for!
TomB_tx Posted 23 minutes ago Share #2 Posted 23 minutes ago Yes - the long pin is a necessary feature of the close focus models as the lens extends further out as is focuses closer. The cut out section is a good idea to allow the normal lens cap to fit without interference. I also have a close focus 1a but the stop pin is not cut out, so the cap rubs against it when mounting Link to post Share on other sites More sharing options...
