HansPAF Posted October 25 Share #1 Posted October 25 Advertisement (gone after registration) Dear forum, For my Leica SL3, I am using primary Peak Design quick-release fasteners, e.g. with a red Steam Robe (12 mm). So far, so good. I have the following problem: The Leica SL3 has rectangular lugs, which means that the thin Peak Design straps do not cover the full width. This means that the cords always slip backwards and the camera basically hangs down. This doesn't happen in this way with a regular wide camera strap. However, I switch between three straps (a wrist strap, the already mentioned red robe, and a wide shoulder strap) and therefore need flexibility when changing the straps. I was able to solve the problem temporarily with wide cable ties, but in my opinion, this is a "not adequate" solution. Does anyone else have this issue and perhaps a solution for me? Thank you in advance for your support. Best regards, Hans Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/424983-sl3-camera-lugs-and-peak-design-quick-release-fasteners/?do=findComment&comment=5882018'>More sharing options...
Advertisement Posted October 25 Posted October 25 Hi HansPAF, Take a look here SL3: Camera lugs and Peak Design quick-release fasteners. . I'm sure you'll find what you were looking for!
MikeZ Posted October 25 Share #2 Posted October 25 I don't have a solution, but am interested if anyone does. I have used Peak fasteners on Sony and Nikon cameras with wonderful results since those cameras have "standard" lugs which are easily adapted to the Peak design. As you mentioned, the strap connector on Leica (and Canon) does not cleanly adapt to the Peak fastener which leaves a certain level of discomfort. FWIW, the Peak connectors on my Canon R5 have held-up perfectly over 3-4 years of use showing no real wear, but that does not address the original question regarding the "backward slip". Any ideas/advice? 1 Link to post Share on other sites More sharing options...
jaapv Posted October 26 Share #3 Posted October 26 I must confess that this is the first time that I know of somebody who sees this as a problem. In fact, I think that it is preferable that a camera is lens down, as I wear the strap diagonally, much more comfortable. It prevents quite a few slams into surrounding objects and people and relieves strain on the mount with heavy lenses. In your place I would contact Peak and see whether they have a meaningful answer. With really heavy lenses I will attach the strap to the tripod mount of the lens using the Peak accessory and it always balances beautifully horizontal with the camera upside down, preventing zoom creep. 6 Link to post Share on other sites More sharing options...
Jonathan Levin Posted October 26 Share #4 Posted October 26 (edited) +1 jaapv! In addition, my arm kind of covers camera for a bit of protection and makes it a bit more difficult to see I’m carrying around a 15k rig. Edited October 26 by Jonathan Levin Link to post Share on other sites More sharing options...
PhotoCruiser Posted October 26 Share #5 Posted October 26 vor 7 Stunden schrieb jaapv: In your place I would contact Peak and see whether they have a meaningful answer. Yep, this would be the best solution. Second would be to use another brand of quick-release or just get used that lens is pulling the camera down. My SL2 has the same wide lugs but i found a hand strap what fit them as i never use shoulder strap, hand strap only. You may do a search here, i remember that others complained about the same problem with the wide lugs. Chris 1 Link to post Share on other sites More sharing options...
Jeff S Posted October 26 Share #6 Posted October 26 (edited) 13 hours ago, jaapv said: I must confess that this is the first time that I know of somebody who sees this as a problem. In fact, I think that it is preferable that a camera is lens down, as I wear the strap diagonally, much more comfortable. It prevents quite a few slams into surrounding objects and people and relieves strain on the mount with heavy lenses. In your place I would contact Peak and see whether they have a meaningful answer. With really heavy lenses I will attach the strap to the tripod mount of the lens using the Peak accessory and it always balances beautifully horizontal with the camera upside down, preventing zoom creep. Same, using PD base plate and one lug, with big 24-90, either cross body or over one shoulder. (PGYTECH strap works similarly.) Not only does lens hug hip, but grip is in perfect position to quickly raise camera to eye. Edited October 26 by Jeff S 2 Link to post Share on other sites More sharing options...
HansPAF Posted October 27 Author Share #7 Posted October 27 Advertisement (gone after registration) Thank you for your kind replies. Well, basically, I don't doubt the stability of the design, and perhaps it's also because, as someone with autism (L1): In my opinion, it's not as it should be 😉 Indeed, it is a good idea to get in contact with Peak Design. However, everything becomes more balanced when I fasten the wide strap. Even so, it looks like this problem only affects a smaller number of people. I appreciate your responses once more and hope you have a pleasant time. 1 Link to post Share on other sites More sharing options...
Photoworks Posted October 27 Share #8 Posted October 27 Would it get better if you insert it from the top > down, the main part of the strap would have the force closer to the camera. In your image, it looks like you have inserted the robe from the bottom. Link to post Share on other sites More sharing options...
SolarChronicle Posted October 27 Share #9 Posted October 27 "This means that the cords always slip backwards and the camera basically hangs down." Having the camera angled downward like that is preferable IMO if you wear the strap over your shoulder, as it prevents the rear LCD from rubbing against your clothing or the rivets on your jeans. 2 Link to post Share on other sites More sharing options...
abakan Posted October 28 Share #10 Posted October 28 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/424983-sl3-camera-lugs-and-peak-design-quick-release-fasteners/?do=findComment&comment=5884200'>More sharing options...
PhotoCruiser Posted October 28 Share #11 Posted October 28 Thats a very nice hand strap 😍 Mine is a cheapo version from Amazon and for my SL2, but i works well just don't look so nice. Do you have a link for it? As i wrote earlier i hate neck straps and for all of my life used the neck strap wrapped around my hand and camera is either in my hand or in a bag. The first hand strap was the Leica Finger Loop for my Q2 and i started to love it so i got one for the SL2. But thats me and probably not OP's solution. Chris 1 Link to post Share on other sites More sharing options...
jaapv Posted October 28 Share #12 Posted October 28 I hate neck wraps as well, with the camera bouncing off your tummy and the lens pointing. Therefore I always wear a camera on a diagonal strap. Left hand side so I can grab it in the correct hold without looking. Wrist straps are encumbering I find; I like to have both hands free, and heavier gear is hard on the wrist and tiring. 2 Link to post Share on other sites More sharing options...
LocalHero1953 Posted October 28 Share #13 Posted October 28 Another long term handstrap user here - Herringbone Heritage. But I agree, @abakan's strap looks nice. Link to post Share on other sites More sharing options...
abakan Posted October 28 Share #14 Posted October 28 Good afternoon! You also have skin masters. Good luck! Link to post Share on other sites More sharing options...
HansPAF Posted October 29 Author Share #15 Posted October 29 (edited) Am 27.10.2025 um 21:00 schrieb SolarChronicle: "This means that the cords always slip backwards and the camera basically hangs down." Having the camera angled downward like that is preferable IMO if you wear the strap over your shoulder, as it prevents the rear LCD from rubbing against your clothing or the rivets on your jeans. Yes, that's a good point. However, when I carry the camera in my hands with the strap or have it slung over my shoulder, this causes problems. In A, the camera hangs as expected. In B, the camera is crooked, and the lower edge presses against one side of my body. I also can't see the display or the settings on the lens anymore, which is annoying. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited October 29 by HansPAF Picture resized Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/424983-sl3-camera-lugs-and-peak-design-quick-release-fasteners/?do=findComment&comment=5884905'>More sharing options...
HansPAF Posted October 29 Author Share #16 Posted October 29 Am 28.10.2025 um 09:50 schrieb abakan: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! What a great alternative! I'm afraid I can't see the manufacturer. Could you please tell me the name of the maker? Link to post Share on other sites More sharing options...
jaapv Posted October 29 Share #17 Posted October 29 1 hour ago, HansPAF said: Yes, that's a good point. However, when I carry the camera in my hands with the strap or have it slung over my shoulder, this causes problems. In A, the camera hangs as expected. In B, the camera is crooked, and the lower edge presses against one side of my body. I also can't see the display or the settings on the lens anymore, which is annoying. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! If you carry it on your shoulder, you won't see the display or lens markings anyway. With the heavier SL lenses the front will tip down regardless of strap. And if you wear the strap diagonally, the discomfort disappears-try it. 1 Link to post Share on other sites More sharing options...
jaapv Posted October 29 Share #18 Posted October 29 Proof. The angle of the diagonal strap pulls the top of the camera against the body Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/424983-sl3-camera-lugs-and-peak-design-quick-release-fasteners/?do=findComment&comment=5884987'>More sharing options...
Elliot Harper Posted October 29 Share #19 Posted October 29 51 minutes ago, jaapv said: Proof. The angle of the diagonal strap pulls the top of the camera against the body Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! I wear my SL3-S with APO 21mm SL lens in a similar fashion except sometimes I use a peak design base plate to hold the other end of the anchor, I feel that way is more balanced and comfortable wearing across my body 1 Link to post Share on other sites More sharing options...
Jeff S Posted October 29 Share #20 Posted October 29 (edited) This is similar to way my 24-90 hangs down when using one lug and the base plate anchor. Can also work over one shoulder. Grip is perfectly placed for right hand, and lens doesn’t stick outward and become susceptible to bumps. https://camerax.com/wp-content/uploads/2021/08/445-02265-09.jpg Edited October 29 by Jeff S Link to post Share on other sites More sharing options...
