GMB Posted Wednesday at 12:36 PM Share #1 Posted Wednesday at 12:36 PM Advertisement (gone after registration) Used the original M20 EVF on my M10R for the first time after many months. The camera only shows LV in the EVF and not on the display although the switch between the two is set to automatic. Same for play, auto review, and menu. I cleaned the contacts. Did a camera reset. Cleaned the back of the camera. Cleaned the EVF. Nothing helps. Any thoughts/suggestions? Georg PS: No chance to walk into a Leica dealer. I am traveling in Bolivia and Peru. Also, cannot test on my M10M which is at home. Link to post Share on other sites More sharing options...
Advertisement Posted Wednesday at 12:36 PM Posted Wednesday at 12:36 PM Hi GMB, Take a look here M10R - LV automatic switch not working. I'm sure you'll find what you were looking for!
mujk Posted Wednesday at 05:31 PM Share #2 Posted Wednesday at 05:31 PM Your description of the problem indicates that the proximity sensor in the EVF does not work. Alternatively, the sensor is fooled by some external (or internal) object or phenomenon to think that you have lifted the camera to your eye. Based on a few tests I just made, a reflective object can be about 10cm away from the EVF to trigger the sensor. Any strong sources of IR light nearby? Link to post Share on other sites More sharing options...
GMB Posted yesterday at 01:11 AM Author Share #3 Posted yesterday at 01:11 AM 7 hours ago, mujk said: Your description of the problem indicates that the proximity sensor in the EVF does not work. Alternatively, the sensor is fooled by some external (or internal) object or phenomenon to think that you have lifted the camera to your eye. Based on a few tests I just made, a reflective object can be about 10cm away from the EVF to trigger the sensor. Any strong sources of IR light nearby? Thanks. I tested it in various scenarios (inside, outside) but all the same. Cleaned the EVF because I expected that the sensor may be fooled. Unfortunately, I do not know where exactly the sensor sits. Link to post Share on other sites More sharing options...
mort linder Posted yesterday at 03:44 AM Share #4 Posted yesterday at 03:44 AM my evf viewfinder has the same problem . i have it set to show in the evf when lv is activated , but play , menu , auto review are set to automatic , but they only show in the evf . if i want to show the menu on the screen , then i just pull the evf back disengaging it . Link to post Share on other sites More sharing options...
mujk Posted yesterday at 07:44 AM Share #5 Posted yesterday at 07:44 AM 6 hours ago, GMB said: Thanks. I tested it in various scenarios (inside, outside) but all the same. Cleaned the EVF because I expected that the sensor may be fooled. Unfortunately, I do not know where exactly the sensor sits. I found some teardown pictures on the web (https://www.yukosteel.com/2024/05/disassembly-leica-visoflex-typ-020.html). The sensor is apparently above the finder window, behind the black area of the cover glass. Unfortunately it seems that you have a faulty sensor. Link to post Share on other sites More sharing options...
GMB Posted yesterday at 01:55 PM Author Share #6 Posted yesterday at 01:55 PM Thanks. I will try to clean the EVF once more. If that does not help, I have to wait until I get home and can test it with my M10M. Link to post Share on other sites More sharing options...
