don daniel Posted August 2 Share #21 Posted August 2 Advertisement (gone after registration) If the seller is not an official Leica dealer, I wouldn’t take that risk. 2 Link to post Share on other sites More sharing options...
Advertisement Posted August 2 Posted August 2 Hi don daniel, Take a look here Leica Summilux 35mm FLE II 11726/11727. I'm sure you'll find what you were looking for!
FrozenInTime Posted August 2 Share #22 Posted August 2 (edited) The 35 Summilux FLE II lenses do appear to be frequently showing up second hand ; seems many are not getting along with the lens, and give up after a couple of months. Edited August 2 by FrozenInTime 1 Link to post Share on other sites More sharing options...
Leon Berg Posted August 2 Author Share #23 Posted August 2 vor 14 Minuten schrieb FrozenInTime: The 35 Summilux FLE II lenses do appear to be frequently showing up second hand ; seems many are not getting along with the lens, and give up after a couple of months. And I am trying to find out why that is.. 1 Link to post Share on other sites More sharing options...
Leon Berg Posted August 2 Author Share #24 Posted August 2 Can one of the users of the FLE II confirm, that the focus throw seems somewhat erratic and stiffer in certain segments? A photographer made me aware of that and I want to know if it was only his copy.. Link to post Share on other sites More sharing options...
bcaslis Posted August 2 Share #25 Posted August 2 I wouldn't call it erratic, but on my FLE II the focus ring is somewhat stiffer just before the .7m mark, looser at infinity and close focus. But really this is just a nit, not a real problem. 1 Link to post Share on other sites More sharing options...
elmars Posted August 3 Share #26 Posted August 3 vor 19 Stunden schrieb Leon Berg: Can one of the users of the FLE II confirm, that the focus throw seems somewhat erratic and stiffer in certain segments? A photographer made me aware of that and I want to know if it was only his copy.. I cannot confirm this. My copy runs the same in all areas. But I had something like this with my FLE I. Leica Service fixed it. But sometimes you can imagine such phenomena, especially when using portrait format with the focussing tab. Due to the different leverage effect, the focus seems to move differently than when using landscape format. 1 Link to post Share on other sites More sharing options...
RMF Posted August 3 Share #27 Posted August 3 Advertisement (gone after registration) 18 hours ago, bcaslis said: I wouldn't call it erratic, but on my FLE II the focus ring is somewhat stiffer just before the .7m mark, looser at infinity and close focus. But really this is just a nit, not a real problem. Yes, mine too originally. After quite a bit of usage mine smoothed up quite a bit but still not perfect. Not sure if this is a design issue with the FLE2, a tolerance issue or manufacturer issue. It does get better with use though. 1 Link to post Share on other sites More sharing options...
SudaliuS Posted August 4 Share #28 Posted August 4 (edited) On 8/2/2025 at 10:23 PM, Leon Berg said: Can one of the users of the FLE II confirm, that the focus throw seems somewhat erratic and stiffer in certain segments? A photographer made me aware of that and I want to know if it was only his copy.. My FLE II works great. The focus ring is tight and smooth in all places. Very sharp at f1.4. I tried several 35mm lenses before it and none of them showed such a sharp picture across the entire frame at an open aperture. This is a modern device with top optics, working great on both digital and analog cameras. Indeed, many have quibbles with this lens, but this is due to its high cost. There are not as many of them on the secondary market as the guys write. I did not compare it with the first version of the FLE, because there was no opportunity. One way or another, the lens needs to be looked at in person and very carefully. Without any shipments. So that you can check everything yourself. Then you can sacrifice the warranty. Edited August 4 by SudaliuS 1 1 Link to post Share on other sites More sharing options...
Leon Berg Posted August 4 Author Share #29 Posted August 4 vor 16 Minuten schrieb SudaliuS: My FLE II works great. The focus ring is tight and smooth in all places. Very sharp at f1.4. I tried several 35mm lenses before it and none of them showed such a sharp picture across the entire frame at an open aperture. This is a modern device with top optics, working great on both digital and analog cameras. Indeed, many have quibbles with this lens, but this is due to its high cost. There are not as many of them on the secondary market as the guys write. I did not compare it with the first version of the FLE, because there was no opportunity. One way or another, the lens needs to be looked at in person and very carefully. Without any shipments. So that you can check everything yourself. Then you can sacrifice the warranty. I am very happy to read about your experiences with the lens. It read like a rational report about it. Thank you very much. 1 Link to post Share on other sites More sharing options...
chris7273 Posted August 4 Share #30 Posted August 4 (edited) I’ve had the Summilux 35mm FLE 2 since January 2023 and I’m very satisfied with it. I have another 35mm : an old summaron 35mm f/2.8 from my grandfather (goggle less type). I’m not a professional photographer — this lens is my “notebook” lens. Here’s a link (flickr) to a few modest images I’ve collected since I got it. They reflect my photographic style and what I can do with this 35mm. Some are heavily cropped and edited, which showcases the advantages of the M11’s fabulous sensor (size and dynamic range). https://flic.kr/s/aHBqjCpDMS and below : 9 examples from this gallery Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited August 4 by chris7273 3 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/423430-leica-summilux-35mm-fle-ii-1172611727/?do=findComment&comment=5843370'>More sharing options...
Leon Berg Posted August 4 Author Share #31 Posted August 4 I am happy that you like your copy and use all of its capabilities. In the end it comes down to a certain tendency to criticize Leica products because of their high price which I am also prone to. We expect the best and don't want anything to be verschlimmert.. meaning aggravated.. I like it as pure as possible.. I don't need and want the closer focus (that's what I say now, never having used the lens) Anyhow, I think I am gonna save the difference and invest in an 11663 or 11675 (I lean towards silver) and be happy ever after... Link to post Share on other sites More sharing options...
chris7273 Posted August 4 Share #32 Posted August 4 In the end, a lens is just a tool 🙂 Link to post Share on other sites More sharing options...
Leon Berg Posted August 5 Author Share #33 Posted August 5 And I am glad, you found the right one for you and enjoy using it. Meanwhile the deal I was after is off and I am getting a used serviced copy of the old FLE, which seems to be the perfect tool for what I want to do right now. Thanks to all four your time. 2 Link to post Share on other sites More sharing options...
