mackgoo Posted June 21 Share #1 Posted June 21 Advertisement (gone after registration) So I cleaned my sensor the other day. A couple things. 1. When I dragged the swab across the sensor and I got close to the other side the swab gets to 90degrees the edges seem to make contact with the enclosure the holds the sensor creating a dragging feeling. Does everyone experience that? 2. I have an M10D so I need to rely on taking a picture of a light background to evaluate the sensor. In this case make sure the monitor you"re using to evaluate is itself clean. :0 1 Link to post Share on other sites More sharing options...
Advertisement Posted June 21 Posted June 21 Hi mackgoo, Take a look here Sensor cleaning. I'm sure you'll find what you were looking for!
250swb Posted July 6 Share #2 Posted July 6 On 6/21/2025 at 3:10 AM, mackgoo said: So I cleaned my sensor the other day. A couple things. 1. When I dragged the swab across the sensor and I got close to the other side the swab gets to 90degrees the edges seem to make contact with the enclosure the holds the sensor creating a dragging feeling. Does everyone experience that? 2. I have an M10D so I need to rely on taking a picture of a light background to evaluate the sensor. In this case make sure the monitor you"re using to evaluate is itself clean. :0 Use an m43 or APSC size swab on full frame cameras, it gets into the corners better and doesn't 'drag'. And yes, good idea, don't sneeze on your monitor. Link to post Share on other sites More sharing options...
