Another way to connect your camera to the generator is a sync cord. I use a 5 meter red Broncolor cord to a hotshoe adapter. Mine is made by Kaiser many years ago. Actually, I prefer the cord over the radio transmitters because the transmitter lasts about two hours on a set of fresh batteries. The cord is power independent. I have seen many other sync adapters over the years, but my Kaiser is still working.
https://www.camerahouse.com.au/promaster-hot-shoe-pc-sync-adapter?srsltid=AfmBOorAuZM8grikyTZPwimaVMIbKMQI7NsrTaen5G9BVnR45MTqTWZ-
Or the Leica sync chord.
Posted (edited)
16 minutes ago, John McMaster said:
There is no cable socket on a Pulso 4....
john
Oh. I didn’t know that. We use the Verso and Grafit packs.
Is there an optical slave receiver? Then a small on camera flash can trigger the generator. I haven’t seen the old IRS (infrared) triggers anywhere for decades.
yevgeny
Edited by ynp
john
My friend who used the older Broncolor units before said that as far as he remembered the cable socket should be under the lid, near the three pin power socket. I cannot confirm that myself because I am not familiar with the Pulso.
yevgeny
8 minutes ago, Pieter12 said:
Is it not the same as the S 006 sync cord?
The same. Blue.  I don’t recall the number. The older ones for the S2 will not fit, as I remember it was pink in color.
yevgeny
There is a hole there, to small for 1/4" and 3.5mm feels too loose (I know I have a phono-3.5mm adapter somewhere....)
thanks
john
