I had trouble with this but the SL2 S Menu shows two levels and clicking on what you think is the update initiating selection isn't active and one must click on the top selection "camera Firmware Version" where another sub selection appears to start firmware.
2 hours ago, rmgbenschop said:
Did you format the SD cards in your Leica?
For me personally this was the only way to get the firmware update to work. When I format the SD card on my Mac the firmware file couldn't be found.
That happens if you use the Disk Utility. For SD cards you should use SDFormatter. Free download.
https://www.sdcard.org/downloads/formatter/
I use an antique 2.0 GB SD card, format in SD Formatter and download the firmware directly to the card. Has not failed for the last 20 years.
9 hours ago, rmgbenschop said:
Yea but no, I should not download and install extra software when it's not needed.
Just format it in your camera and follow the instructions.
That software is not "extra". It is the official formatting tool by the SD Association to restore the SD card to factory settings - an essential tool for anybody who uses SD cards. The camera format is limited. It just wipes the card and inserts the camera folders. But it does not check and -if needed- restore the memory structure.
