JLV Posted 13 hours ago Share #1  Posted 13 hours ago Advertisement (gone after registration) WIth  6.2.0 firmware The P and S mode have disappeared. I can only switch  from A to M. I reset the camera and started again to set my customisation of the buttons but still no option to get S and P. Does anybody could figure what is happening and if I did something wrong? Thanks for taking time to answer. 1 Quote Link to post Share on other sites More sharing options...
Advertisement Posted 13 hours ago Posted 13 hours ago Hi JLV, Take a look here P and S mode disappear with new SL2S firmware ! HELP!. I'm sure you'll find what you were looking for!
Photoworks Posted 13 hours ago Share #2 Â Posted 13 hours ago Are you using an M lens? 1 Quote Link to post Share on other sites More sharing options...
JLV Posted 2 hours ago Author Share #3 Â Posted 2 hours ago Yes, coded and also non coded. I just tried with the 35 Cron SL and I have all the modes! A friend who uses a 50 mm Cron R has all the modes with a SL2S too.. Best, 1 Quote Link to post Share on other sites More sharing options...
Chris Nebard Posted 1 hour ago Share #4  Posted 1 hour ago I think Photoworks (post #2) is alluding to the fact that, if you attach an M lens to your SL2-S, you will automatically lose the P and S modes. The camera will only operate in Manual (M) and Aperture Priority (A) modes - ie where you change the aperture via the lens’s aperture ring. In Shutter Priority (S), where you choose the shutter speed yourself, the camera is unable to select the aperture on a manual lens. Similarly, in Programme (P) mode, the camera could not choose the aperture on a manual lens with an aperture ring. Therefore, S and P are automatically disabled when a manual M lens is attached. This applies to the previous firmware as well - you just may not have noticed it. Hope this makes sense and is helpful. Quote Link to post Share on other sites More sharing options...
LocalHero1953 Posted 1 hour ago Share #5 Â Posted 1 hour ago P and S mode require the lens to have electronic aperture control. That's not possible with M lenses, coded or non-coded. You would not have had Pand S mode with M lenses before the update either! User error, I'm afraid! 1 Quote Link to post Share on other sites More sharing options...
frame-it Posted 1 hour ago Share #6 Â Posted 1 hour ago 1 hour ago, JLV said: Yes, coded and also non coded. I just tried with the 35 Cron SL and I have all the modes! Â Brilliant Quote Link to post Share on other sites More sharing options...
HoodedOne Posted 1 hour ago Share #7 Â Posted 1 hour ago Advertisement (gone after registration) 39 minutes ago, LocalHero1953 said: P and S mode require the lens to have electronic aperture control. That's not possible with M lenses, coded or non-coded. You would not have had Pand S mode with M lenses before the update either! User error, I'm afraid! This is not correct. I've not upgraded the firmware yet. And i can still select all modes with the LLL 50/2 Rigid on a Urth adapter. Quote Link to post Share on other sites More sharing options...
LocalHero1953 Posted 17 minutes ago Share #8 Â Posted 17 minutes ago 54 minutes ago, HoodedOne said: This is not correct. I've not upgraded the firmware yet. And i can still select all modes with the LLL 50/2 Rigid on a Urth adapter. I look forward to hearing how the camera controls the aperture on a manual aperture lens. 1 Quote Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted 8 minutes ago Share #9  Posted 8 minutes ago I just can’t be bothered to check my cameras. I haven’t upgraded yet. But anyway… Even if they do display P and S modes with M lenses those modes won’t work. Likely Leica just got around to removing them for P and S modes for those who hadn’t worked that out for themselves. Paul is correct. You get A or M modes for M lenses. You never got the others regardless of the camera display. Gordon Quote Link to post Share on other sites More sharing options...
