Erwin74 Posted May 5 Share #1 Posted May 5 Advertisement (gone after registration) Hello, I would like to know if the Exifs are available in RAW when mounting a Zeiss ZF2 lens with the Novoflex SL/NIK adapter (with contactors) on SL/SL2-S/SL2 cameras? Thanks in advance! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/421015-zeiss-zf2-leica-sl-sl2-s-sl2/?do=findComment&comment=5797139'>More sharing options...
Advertisement Posted May 5 Posted May 5 Hi Erwin74, Take a look here Zeiss ZF2 & Leica SL, SL2-S, SL2. I'm sure you'll find what you were looking for!
Biotar Posted May 5 Share #2 Posted May 5 (edited) I use the ZE versions from Zeiss on the SL2-S via Sigma MC-21 and it writes the focal length, maximum aperture and aperture used in the exifs. The camera also applies the focal length for the stabilizer. Here is an example for the Otus 85 (left) and Planar classic (right) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited May 5 by Biotar 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/421015-zeiss-zf2-leica-sl-sl2-s-sl2/?do=findComment&comment=5797166'>More sharing options...
Biotar Posted May 5 Share #3 Posted May 5 But I have never seen the Novoflex adapter and it is most likely no longer manufactured? 1 Link to post Share on other sites More sharing options...
Erwin74 Posted May 5 Author Share #4 Posted May 5 Thank you for your answer! The lens name is not communicated in the exifs? I'm looking for informations about Zeiss ZF mount. The Novoflex SL/NIK adapter is no longer manufactured. Link to post Share on other sites More sharing options...
BernardC Posted May 6 Share #5 Posted May 6 16 hours ago, Biotar said: But I have never seen the Novoflex adapter and it is most likely no longer manufactured? The Novoflex adapter is only compatible with the original SL (2015). Later models such as the SL2, SL3, and all Sigma, Lumix, and Blackmagic L-mount cameras are incompatible with the Novoflex adapter and should use Sigma's adapter instead. 1 1 Link to post Share on other sites More sharing options...
Erwin74 Posted May 6 Author Share #6 Posted May 6 As far as I know, there are no Sigma adapters with contactors for Nikon F Mount. Link to post Share on other sites More sharing options...
Biotar Posted May 6 Share #7 Posted May 6 Advertisement (gone after registration) vor 23 Minuten schrieb BernardC: The Novoflex adapter is only compatible with the original SL (2015). Later models such as the SL2, SL3, and all Sigma, Lumix, and Blackmagic L-mount cameras are incompatible with the Novoflex adapter and should use Sigma's adapter instead. good to know vor 3 Minuten schrieb Erwin74: As far as I know, there are no Sigma adapters with contactors for Nikon F Mount. I believe that the (Sigma-) ZE version is the better option anyway, simply because of the focus direction that suits Leica. 1 Link to post Share on other sites More sharing options...
Erwin74 Posted May 6 Author Share #8 Posted May 6 vor 4 Minuten schrieb Biotar: good to know I believe that the (Sigma-) ZE version is the better option anyway, simply because of the focus direction that suits Leica. Yes, but I prefer the ZF version with the aperture ring, which are adaptable to all camera brands. Link to post Share on other sites More sharing options...
Biotar Posted May 6 Share #9 Posted May 6 Sure, but if you can already use an automatic aperture, you do it. You will never use the aperture ring anyway if the camera can control it. As far as I know, the aperture ring for open aperture metering on Nikon must also be set to A? Canon EF also works on Sony, Fuji and MFT (Metabones, for example). 1 Link to post Share on other sites More sharing options...
