At times ( no reason) the connectivity on M11D camera is off between Leica Fotos and the body ( got latest version of both on) and  I have to  re enable it manually by holding the thumb wheel for 12 seconds.  Is there something I do wrong and it is painful?
x
Exactly as above.
Take the phone all the way back to its pre-installation condition.
Then do a clean reinstall with a fresh download of the latest version of the app.
Things have stabilized over time. I had similar instances in the past, took these steps, and have not had any connection issues in a long time.
10 hours ago, DadDadDaddyo said:
Exactly as above.
Thanks but it did not solve the problem. First connection was fine, second not and third  was fine. Anything else?
Did you include a phone reboot and a full camera reset as part of the process? Do these after un-installing the app from the phone and after deleting the phone as a connection on the camera, and before re-installing. Might help clear the slate.
I suggest these only because they're just general good practices. Even after an un-install, bits of code might remain resident (in working RAM, even if not in storage). The reboot and reset should clear that out, prior to reinstallation.
It's just a thought, and I hope it'll help.
