Guest moonwrack Posted January 5, 2008 Share #1 Posted January 5, 2008 Advertisement (gone after registration) I have a ca 1956 f4.5 135mm Hektor. Some haze around the circumference but it works well. I am wondering why the front barrel section of the lens unscrews, but not far enough to be removable? Link to post Share on other sites More sharing options...
Advertisement Posted January 5, 2008 Posted January 5, 2008 Hi Guest moonwrack, Take a look here 135mm Hektor . I'm sure you'll find what you were looking for!
Mark Antony Posted January 5, 2008 Share #2 Posted January 5, 2008 I think your Hektor does unscrew into 2 separate parts. The reason for this is that they could be used with the Visoflex housing. I know my 90mm Elmar comes apart, and should help when you want to clean the back element. Mark Link to post Share on other sites More sharing options...
zeitz Posted January 6, 2008 Share #3 Posted January 6, 2008 The full front section, which includes the aperture ring, is removable for use on PLOOT and Visoflex I. The correct short focusing mount that takes the lens head is ZOOAN. All these pieces can be bought very cheaply. They were made is large numbers. The very ealiest 135 mm Hektors, from about 1935, do not work this way. Link to post Share on other sites More sharing options...
LeonardT Posted January 27, 2008 Share #4 Posted January 27, 2008 I have a ca 1956 f4.5 135mm Hektor. Some haze around the circumference but it works well. I am wondering why the front barrel section of the lens unscrews, but not far enough to be removable? Hello Peter, I also have a 1956 135 Hektor. The head on mine unscrews very easily. There are no screws to loosen or anything else to prevent the head from being removed. The only thing I can think of is the top thread inside the tube might be buggered up. I don't think I would force the lens though. Enjoy it as is. Or get it fixed and the haze cleaned up at the same time. Len Link to post Share on other sites More sharing options...
