x
I also have issues but with SL2. I removed the camera and tried again, which worked okay. Then I connected it in the field, and the app disconnected after a minute.
However, somehow the camera noted my GPS position and applied it to all images.
Am 21.1.2025 um 12:52 schrieb Filip Baraka:
The GPS application to your photos has nothing to do with the connection of the camera to the app. It has to do with Fotos but it works without connection (once you have setup the connection in the first place as you did).
Am 21.1.2025 um 11:57 schrieb Loneshooter:
Hi everyone,
Since the update to the last FOTOS version on iOS 18.2.1, I'm not able to connect anymore my SL3 to the app, it's only me?
Thanks for the feedbacks
Have you reconnected your camera? Have you - before attempting to reconnect - deleted the Bluetooth entry of your camera in the BT settings of your iPhone? And only now try to reconnect.
vor 3 Stunden schrieb Loneshooter:
Any other experience of this problem?
I was out today to shoot a bit as it was finally warm and sunny.
The whole GPS coordinates system over the Fotos app work surprisingly well but has some quirks as the one i encountered today.
Fotos tell me that camera is not connected and could not connect so i did a forced restart of my iPhone 15 Pro Max and after i could connect but was already about 500 yards further.
When i checked at home the photos all - also the one when Fotos said that the SL2 is disconnected - are geotagged so basically all fine and much better as back in 2020 when i had mucho mucho problems with geotagging on my Q2 where is also a tread from me about that.
It seems Leica made it that geotagging work stable, it's just the messages are confusing.
From what i remeber on the Q2 there are two connections
Bluetooth -> for geotagging and establishing the WiFi connection
WiFI -> to view and download the photos as bluetooth would be too slow for that
If it still does not work do one step more if you have a iPhone(iPad
do a forced restart after you removed the camera in bluetooth menu and the Fotos App
After the forced restart install Fotos again and then follow the steps to pair and then connect the camera.
Search the Apple help site for forced restart for your devices
Chris
Edited by PhotoCruiser
Latest Fotos update (1 week ago) needs at least IOS 17.0 according to IPad AppStore
The most recent "up to date"  on my IPad OS is ver. 16,x.x. -
That is probably the reason that none of my cameras can connect to Photos on IPad (any more? or for the moment?) ...
-Mikkel
Can't connect M11 and SL3 any more, since I updated the App on Monday.
My iPhone is running iOS 18.3. Everything worked fine before the update. I set back my phone (network connections), I set back the cameras, installed the app again, but evertime the same problem shows up. The App finds the camera, connects via bluetooth, but then it does never find the camera to connect fully.
Anny suggestions?
Kindly, Karl
I run Fotos on my iPhone 15 Pro Max and a iPad 12.9 6th gen, both with newest iOS version, but german.
When your phone connects to the camera but not start the WiFi network then the problem is most likely there as Bluetooth will first connect to negociate the WiFi connection.
Try to delete al remaining Fotos connection parameters on your iPhone and on your camera, uninstall Fotos, do a forced restart as described here
Download Leica Fotos again and install it
Run the setup to connect your camera
Chris
vor 31 Minuten schrieb PhotoCruiser:
Chris
Already done. No effect. Sorry
Do you have the iPhone HotSpot active?
If i have the HotSpot active then either HotSpot does not work or WiFi with Fotos get disconnected.
Can you see your Leica in Bluetooth devices?
Can you see the Leica WiFi in WiFi?
Also disabling the iPhones security settings under Settings --> Wlan --> click on the i right side of Leica WLan (if available, then disable the settings below.
  • Data saving mode
  • Private Wlan Adress
  • IP-Address tracking
Set DNN-Server to default one, not a manual set ip address
You may post your question in the Apple User Forum here:
https://discussions.apple.com/welcome
Chris
I see you have already 18.3.1 installed, so thats not the problem.
Before you think that the camera is faulty, test with another phone and best would be a Android and a other iPhone.
if it still does not work on both phones or tablets then your camera is probably really faulty.
Unfortunately Apple OS's have their quirks and the Apple User Forums are full with wired connection problems, mostly after a OS update.
Chris
I had the problem while being in Japan. During that time, I had a second simcard installed (for data only). As soon as I got home to Switzerland I deinstalled that electronic simcard, and Tadaa, phone reconnects perfectly to both cameras. I don’t know why, but I workes like before.
