I agree it sounds annoying. With the M-D you have to hold down the top plate function button and rotate the wheel at the same time to get EC. So it never happens by accident.
Edited by Datsch
vor 2 Minuten schrieb Datsch:
I agree it sounds annoying. With the M-D you have to hold down the function button and rotate the wheel at the same time to get EC. So it never happens by accident.
I do not have the D any more, but that is not what I remember. The wheel is - besides being the wheel - just like a button: You can (1) just turn w/o pressing or you can (2) press once and then release before turning or (3) you can press twice and release and the turn. However I never turned and pressed in at the same time. That would be a pain.
But unfortunately I just write this from what I remember. Maybe I should stay out of here.
@M11 for me sorry I was talking about the M-D not the M11-D, just to contrast the old and the new approaches that Leica have taken with this.
The M11-D makes it easier to access EC by having on the wheel as default
The M-D makes it a little harder yes, but still quick and instinctive and never by accident
Personally for the rare times I use A mode these days I tend not to use EC anyway and instead half press AE lock by grabbing the speed I want from a darker or lighter corner of the scene and then reframing.
vor 5 Stunden schrieb M11 for me:
- Just turn without pressing: The last activated function is still activated and just works.
- Press once: You see which function is activated and then you can rotate the wheel
- Press twice to toggle through the functions: ISO or exp. comp. (or as a speciality the shutter speed when in B )
i think your text should be part of the Leica M11-D manual, @M11 for me !  thank you for the crystal clear explanation !
