Steadimann Posted January 9 Share #1 Posted January 9 Advertisement (gone after registration) Hi, so i did purchased the M9 with replaced sensor and it's on the way.. I wonder what happens and how to proceed when I want to use it with modern lenses release after latest fw update and which are not supported by firmware? It will show up as uncoded and I would have to manually choose the lens to the closest one? Link to post Share on other sites More sharing options...
Advertisement Posted January 9 Posted January 9 Hi Steadimann, Take a look here What happens when fw does not support lens?. I'm sure you'll find what you were looking for!
pedaes Posted January 9 Share #2 Posted January 9 54 minutes ago, Steadimann said: I wonder what happens Nothing happens. If lens if 50mm or lomger I wouldn't bother as '6 bit' adjustments are minimal. For wider than 50 if you want you could try your judgement of a listed lens, and see difference with and without code. Mostly affects vignetting. Link to post Share on other sites More sharing options...
jgeenen Posted January 9 Share #3 Posted January 9 Good question, most likely the code will be ignored and the lens reported as uncoded (that's what happens on my M11, if I use an unknown lens code on a hand-coded lens). In this case you could use an appropriate one from the list or leave it as is. Modern lenses typically do not exhibit a color shift, so only vignetting could be corrected in camera. You should test the result of a specific setting - scenarios are possible where the result is worse than the original (due to color shift correction). In some cases it might not be appropriate to select a closely matching lens type - say a Summicron 2/35 for the modern APO Summicron 2/35, because those two have totally different optical designs. Link to post Share on other sites More sharing options...
Steadimann Posted January 9 Author Share #4 Posted January 9 i'm more worried just to have information on which lens was used on the camera and corrections then are done in Lightroom anyway, but knowing which lens was on would be useful Link to post Share on other sites More sharing options...
pedaes Posted January 9 Share #5 Posted January 9 30 minutes ago, Steadimann said: i'm more worried just to have information on which lens was used on the camera Worried? The only factual data you will get in the EXIF will be from 6-bit coded lenses, or lenses listed in the camera FW. If this is vital your best chance is with whatever M is current and latest FW. Obviously, the older the camera/FW the bigger the disparity with recent lens launches. There has been a couple of cases in the past when we knew a new lens was coming as it was listed in a FW release ahead of announcement. Link to post Share on other sites More sharing options...
Deeetona Posted January 10 Share #6 Posted January 10 Let your eyes decide. Link to post Share on other sites More sharing options...
TomB_tx Posted January 10 Share #7 Posted January 10 (edited) Advertisement (gone after registration) It's understandable that the work to update 8-bit for each older model isn't economically feasible. The codes trigger edge color and vignetting corrections, and those corrections need to be experimentally determined for each different sensor - lens combination - which is a lot more work than just a tweak to recognize the code. But it would be nice just to recognize the lens. I coded my Nokton 35 1.4 ver II as the Steel-Rim Summilux re-issue for my M10, but of course my M9 ignores it. Edited January 10 by TomB_tx Link to post Share on other sites More sharing options...
hjddd Posted January 13 Share #8 Posted January 13 we need new firmware for M240 series and M10 series(M9 series, too,but even less possiblity) Link to post Share on other sites More sharing options...
Ko.Fe. Posted January 19 Share #9 Posted January 19 On 1/9/2025 at 10:28 AM, Steadimann said: I would have to manually choose the lens to the closest one? Indeed. Or just ignore all of it. Coding is overrated if you are using DNG and Lightroom. I keep forgetting to choose 21/4 after 50 1.5 and in the opposite. Nothing significant happen. The only practical reason for coding is to have focal length and somewhat guessed aperture in EXIF. Link to post Share on other sites More sharing options...
