Hi all
I've just picked up a Q3 as a compliment to my current kit and I am in the process of setting it up. My preference for focus would be to have it as AFC single point but be able to switch quickly to a face of my choosing when the need arises. Is there a way that a function button can be set so that when the point is on a person, I can press it and it starts eye detect without it going into a menu?
Apologies if this is obvious, I have zero experience with modern autofocus cameras.
Cheers
Costa
x
Posted (edited)
You can set a fn button so it takes you to the list of focusing methods, but not to directly set one. I’ve been asking Leica for this sort of toggle button (on/off, or direct switch) since the SL(601). It appears that fn buttons can only be made to go to a particular place in the existing menu, not to make a specific selection.
Edited by LocalHero1953
If Leica made quick profile switching with a left-right gesture instead of switching to video mode, it would make a lot of tasks easier, including this one
Posted (edited)
I’m surprised, I am a total autofocus newbie and it was the first thing I thought of. It seems the most intuitive way to use any automated camera nowadays. I mainly shoot scenes or people but don’t want it to start jumping around to random people or objects unless I ask it to.
Yesterday when I tested it at home, I ended up using it in manual mode for static bits and quickly moving it into AF mode which had the face detection AFC set. It worked quite well but being able to switch to a function without an additional menu would be the way to go imo.
Edited by costa43
That would be a good workaround.
Posted (edited)
Damn that’s a long time, you’d think they would have figured it out by now, or maybe they do not think enough people want it. Surely it cannot be that hard for them to write the software for it to select an item in the sub-menu. We have direct buttons for AFL/AEL and magnification already.
Edited by costa43
  • 1 month later...
You could do this by setting up user profiles for different situations.  My first profile is for my all purpose settings which i call Standard, Then I made additional profiles from the standard one. I also customized the wheel button for changing profiles.  It is easy to switch profiles as needed.
