Same experience here. I spent 3 weeks in Malaysian humidity this summer with my Q2. Had the same fogging issue one morning, which cleared after 10 minutes, and for the rest never had the slightest problem with humidity, even under torrential rain. As mentioned by @AussieQ, the Qs are built for this.
13 hours ago, AussieQ said:
I experienced exactly the scenario you are concerned with. I was in South Korea in August and it was stinking hot and humidity levels were insanely high. The first morning I ventured out of my reverse cycle air conditioned room my Q3 lens fogged up.In about 10mins it cleared and oddly, though I still used aircon each night in room, the lens never fogged up ever again. At times it was pouring rain and I still kept the Q3 around my neck and yes it got very wet, but its built for it. You will be fine.
Thanks!  I really appreciate it.
Thank you very much!  That helps!
  • 5 weeks later...
Well you probably are already back, but it may matter to someone else.
I had my Q2 twice in Costa Rica and Panama and had no issues at all, not even fogging.
She will fog if she is too cold and then brought out to the hot and humidity condenses so i suggest to keep A/C temperature in your room/car as high as possible and/or store the camera in fluffy towels or a cooler to reduce that she get cold and will fog up.
Chris
