1 hour ago, Tuan Anh said:
DNG-> Internal,JPEG->SD card.
My SD is Kingston USH-II V90 with 200MB/s write.
It looks to me like your internal memory was in fact (almost) full (born out by the image from your computer).
if reformatting the internal memory solves the problem that bears it out.
Or am I missing something?
best
Jono
Edited by jonoslack
x
best
Jono
Format the internal memory solves the problem but it comes back eventually.3rd times already.
I had 3GB of DNG photos when it happened,3GB over 256GB and it was full.
Many 11-P users have the same issue,too.Happens only using FOTOS.
But if you are sending jpgs to the Internal and leaving them then surely it will fill up eventually?
Hey,
if you buy a small usb-c stick Like this >
>  https://www.mediamarkt.de/de/product/_sandisk-ultra®-dual-drive-go-2609988.html?storeId=260&utm_source=google&utm_medium=cpc&utm_campaign=RT_shopping_na_nsp_na_PLA+-+bluePortal+3+PMax&gclsrc=aw.ds&gad_source=1&gbraid=0AAAAADh5KajTxhJ2j9hqwQ0B39Ftsqmxp&gclid=CjwKCAiAqrG9BhAVEiwAaPu5zmllLiNDTKIMmE0lKlW-wVhu1-SS2ZuRQ5G1gFdYrsmmtVqKLVKArxoCfKkQAvD_BwE
Then you can just format the complete internal SSD and you a free to fill it up again.
I use this usbc sticks as additional back up.
They are small ,, I can access the images on my iPhone if I need (or android) and I don't need the camera as mass storage.
cheers Peter
6 hours ago, Tuan Anh said:
Doesn't it say the memory is almost full and you only have 3GB left?
Maybe you can write the problem in your native language and use deepL to translate?
https://www.deepl.com/de/translator
I don't get the problem....
Transferring images using  FOTOS does not remove the DNG file you told the camera to place in internal memory.  Either format the card or delete the images by using the menu after hitting the play button.  Note that if there are images both on the card and in internal memory you must "delete all" twice.  The first time it deletes the images on the card, the second time it deletes the images in internal memory.  That's how it works on my camera where I have Internal = SD card.
No,i had only 3GB of photos and it bugged full memory.Not like i had 253 GB of photos and had 3GB free left.
It looks like i had full of photos but i didn’t.The screenshot on my PC just shows how the memory is bugged.
Edited by Tuan Anh
i store Jpeg on SD and leave internal memory untouched now.But it still bugs the internal memory.Note:No photo in internal memory.
5 hours ago, Pelu2010 said:
Hey,
cheers Peter
Thanks.But here is the problem.I describe what happened to my camera just now,this is 3rd time.
This time,i don’t have any photo in internal memory,it has 0 file.Totally free of 256GB of memory.Newly format.I shoot JPEG and photos are stored in SD-card.Once again,internal memory is untouched.
However when i download photos from camera using FOTOS via WIFI.it bugs internal memory to full,leading to the “internal memory full” message comes up on camera.The only way to fix it is format it and i know how to format.
Edited by Tuan Anh
Are you deleting them when you've copied them across? What is your process?
I always delete the photos that i don’t like.Even if i didn’t delete,i couldn’t fill up the memory.I got the camera 3 weeks ago and i don’t take photo everyday.
Other M11-P users experience the same bug,too.Reported from M11 groups and other Leica community.I emailed Leica and they will look to it,hope there will be a patch coming soon.
Meanwhile,i don’t store photos on internal memory or using cable to download.Only bug when using Wifi so far.
3 minutes ago, Photoworks said:
It is good you reached out to leica, they can be slow in fixing bugs
You way want to use the SD for now and see if you get the same problem
the bug really is annoying but not critical.Doesn’t matter where i store shot photos.If i use FOTOS with Wifi connection to download the files,the bug has tendency to occur.The internal memory says it full and not allow to store any more photo.But still accessible.
Using cable is so far so good or just take out the SD and use card reader.
vor 9 Stunden schrieb Tuan Anh:
I have tried to reproduce this and have saved images in the camera with your settings. Once I downloaded DNG + JPG via WiFi, then on the second attempt only JPG. No error message both times.
It doesn’t 100% happen everytime,kind of random.It doesn’t occur within couple of times,sometimes it takes like 10-20 cycles or the whole week.Some 11-P users,including i are having this situation.If your camera is 11-P and this bug doesn’t bug you.Hope it never will.
I use iphone 15 pro with ios 18.3.1 with updated FOTOS app.
Here the another user has the same problem.
