paulscr Posted May 24 Share #201 Posted May 24 Advertisement (gone after registration) Likely - I did get this after upgrading to latest firmware. Will do some extensive testing over weekend. Link to post Share on other sites More sharing options...
Advertisement Posted May 24 Posted May 24 Hi paulscr, Take a look here M11-D internal memory fault and freezing. I'm sure you'll find what you were looking for!
paulscr Posted May 24 Share #202 Posted May 24 On 5/23/2025 at 5:06 AM, hdmesa said: When you were seeing there were only 20 photos, was that reviewing in camera? Could you have been reviewing images from the SD card instead of the SSD? I don’t have an SSD in camera. The twenty photos were all I had on internal memory. as someone else pointed out - likely a firmware quirk. Happened after upgrading to latest. Link to post Share on other sites More sharing options...
hdmesa Posted May 24 Share #203 Posted May 24 8 hours ago, paulscr said: Likely - I did get this after upgrading to latest firmware. Will do some extensive testing over weekend. If it happened right after a firmware update, make sure you did a factory reset afterward per Leica’s instructions. 8 hours ago, paulscr said: I don’t have an SSD in camera. The twenty photos were all I had on internal memory. as someone else pointed out - likely a firmware quirk. Happened after upgrading to latest. 1 Link to post Share on other sites More sharing options...
