Jonathan Levin Posted November 9, 2024 Share #1 Posted November 9, 2024 Advertisement (gone after registration) Hi all. I am just now getting set to run a bunch of tests using a Nikon macro (without aperature ring) attached to a Novoflex F to L adapter to the SL3. Probably a clunky setup but it’s what I got for now and I may still be able to use my ES2 slide/film adapter with that. My question: Do I need to change any menu settings i.e. lens profile, focus settings, or anything else to make this work? Live view settings too? I know that I should have prefered focus set to manual. Any other tips? Thanks. Jonathan Link to post Share on other sites More sharing options...
Advertisement Posted November 9, 2024 Posted November 9, 2024 Hi Jonathan Levin, Take a look here Focus setting when using Novoflex adapter?. I'm sure you'll find what you were looking for!
FlashGordonPhotography Posted November 9, 2024 Share #2 Posted November 9, 2024 My SL3’s didn’t like the Novofles adaptors at all. I have both. I only have a few comaptible lenses and none worked on the Sl3 properly where they do on the SL2. I think the Novofles adaptors are end of life. But good luck if you can make one work for you. Gordon Link to post Share on other sites More sharing options...
Jonathan Levin Posted November 9, 2024 Author Share #3 Posted November 9, 2024 Great. Sounds like my list for eBay items is growing! Thanks FGP. I'll give it some run through this weekend. Link to post Share on other sites More sharing options...
Jonathan Levin Posted November 25, 2024 Author Share #4 Posted November 25, 2024 So I borrowed a friends SB 800 to use with the SL3, the Nikor 60 Macro and the Novoflex F-SL adaptor. While it is a bit clunky to use, I did manage to get everything working very well! And as a plus it seemed to work well with the Nikon ES-2 slide copier to, even filling most of the frame. The front Zoom image button on camera made focusing on the film pretty easy. The flash just needed to be the kind that you can set to Non-ttl, be able to set your own ISO and F/stop. Match those setting on camera. So the flash is determining how much light to output. Not perfect, but at least this won't go on eBay for a bit anyway. Link to post Share on other sites More sharing options...
Anbaric Posted November 26, 2024 Share #5 Posted November 26, 2024 (edited) 2 hours ago, Jonathan Levin said: So I borrowed a friends SB 800 to use with the SL3, the Nikor 60 Macro and the Novoflex F-SL adaptor. While it is a bit clunky to use, I did manage to get everything working very well! And as a plus it seemed to work well with the Nikon ES-2 slide copier to, even filling most of the frame. Now you have so much Nikon stuff, your logical next ebay purchase is a Nikon camera. 🙂 Edited November 26, 2024 by Anbaric 1 Link to post Share on other sites More sharing options...
Jonathan Levin Posted November 26, 2024 Author Share #6 Posted November 26, 2024 1 hour ago, Anbaric said: Now you have so much Nikon stuff, your logical next ebay purchase is a Nikon camera. 🙂 NO! Link to post Share on other sites More sharing options...
Jonathan Levin Posted November 26, 2024 Author Share #7 Posted November 26, 2024 Advertisement (gone after registration) SL3 60mm Nikkor AF-s Macro 2.8 G ED attached to Novoflex F-SL adapter. Manual mode Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/416109-focus-setting-when-using-novoflex-adapter/?do=findComment&comment=5713533'>More sharing options...
