I have a Leica UVa filter ref: 13386 and noticed that the glass is a tiny bit loose. If I tap the filter I can hear it rattle around a bit and also noticed it when I was cleaning it. Not like super loose, but I can hear it moving around.
Is this normal?
The B+W and Heliopan filters have a more precise brass mount and I believe that there is a retaining ring which is tightened down around the glass to keep it tight and flat. Are the Leica filters simply expensive and over-hyped?
-Brad
It may be entirely normal. I found this thread from quite a few years back on Photo.net. I believe that Leica and many other filter manufacturers design the filters this way to allow for expansion/contraction due to temperature changes. Maybe the B+W and Heliopan filters do the same thing, but in a more subtle and less noticeable way?
https://www.photo.net/forums/topic/37022-leica-filter-loose/
It's generally assumed that Leica outsources them to one of the major filter manufacturers, and they are 2-3x the price of comparable high quality filters, so...
