Can someone confirm if Sigma i series lenses with aperture ring like 45mm f/2.8 or 24mm f/3.5 are fully compatible with the Leica TL2?
Some people said the manual aperture ring is not working, other said it's working correctly... I read something about battery drain...
My main concern is to be able to use the lens with the aperture ring (not on the lens A mode and setting it on the camera)
Many thanks!!!
Having played around with the 90mm f2.8 DG DN on the CL, the lens is beautifully made, as is the 16mm f1.4 (with no manual aperture ring)…
The “A” (auto) aperture position on the 90 is not something you can “lock down”; I’ve pulled the lens from my bag a couple of times where the switch has move between the “A” and manual f22 setting, and I find myself glancing at the AF/MF switch to make certain it’s where I want it to be.
The camera menu option for focus with the 90 mounted is single or continuous AF only. If one wants to go to full-time manual focus only with the 90 you have to use the AF/MF switch on the lens.
There’s enough handling differences between these DG DN lenses and the Leica TL lenses (of which I own all) it gets your attention, in not necessarily a good way.
  • 2 weeks later...
