Can someone identify a source for a high quality 34mm multicoated UV filter? I usually purchase B&W Master series.  Heliopan seems to have discontinued a multicoated UV filter in this diameter.  Tiffin makes a filter but it’s not multicoated. I prefer to use one with a 34mm screw on lens shade rather than use a step up ring with a larger filter and the have to search for another lens shade.  Amazon lists a filter by Opteka for $4.95 but I’m not convinced of its quality.  Many thanks.
26 minutes ago, rclompus said:
Unfortunately, I have not been able to find any 34mm Hoya UV multicoated filters in stock in the U.S.
Yep, it's discontinued indeed.
You may consider some alternatives such as Hoya or so.
B&H: Hoya 34mm Introductory Filter Kit, für further reference.
The Hoya introductory kit features a UV filter with a single coating.  I am unsure about current listings of Rodenstock filters.  Little information is available.
I solved this by ordering a 39mm B&W UV Pro filter with a 34 to 39mm step up ring.  A short 39mm screw in lens shade as ordered.  If the Voigtlander VM 40/2.8 doesn’t flare, the lens shade may not be necessary.
Thank you to everyone who suggested resources.
Be well, RC
Edited by rclompus
