Accidentally selected the Expressive (Exps) photo style on a shoot. Naturally wondering how one can undo or correct the effect or, not at all.
Shot RAW on D-LUX7
Edited by HpS
Addendum
2 hours ago, jaapv said:
In OOC JPG you cannot undo this, in raw it is not an issue.
They say everything becomes simple when explained. :)
So how is it done exactly. Would you happen to know.
Thank you.
1 hour ago, Al Brown said:
If you know why you shoot RAW then you would also know the answer. No effect style affects RAW file to the point of irreversibility. Almost every camera setting (except lens DoF and/or too slow shutter blur) is reversible on your raw files.
Thank you for replying.
Actually I never use any digital effects available in my digital cameras. I am an old school 35mm and large format film photographer and have really only used filters on B&W and rarely.
Began using digital since 2009, mostly RAW, mainly for resolution and quality, and to tweak colours only to maintain the natural look and feel.
Happy to know the steps if any, to the undoing.
Edited by HpS
Correction
Thank you.
Set the camera to raw+JPGlarge
Don't get you.
Set the camera as above and do what to reverse the effect on photos already shot?
Edited by HpS
Addendum
27 minutes ago, HpS said:
Don't get you.
I believe what they are trying to say is that if you choose the expressive setting, it should only be applied to the JPEG. When you open up the RAW file in a RAW processing program, it should not have any effects applied. What program are you using to adjust your photos? If the effect is automatically applied in your RAW processor, you might need to choose a different profile (if you are using Photoshop or Lightroom, choosing Adobe Standard should normalize the file).
Understand now after reading your response.
I use Photoshop. Before attempting anything on my own had posted here to try and get a handle on this before I start.
Thank you Stuart.
Check in Photoshop Preferences --> File Handling whether you have enabled "Automatically open supported Jpegs and HEICs with settings"  If so, change
Thank you. Shall attempt this.
