Store DNG on CFe and JPG on SD; how can I adjust settings so that when I delete a DNG file, also the JPG gets automatically gets deleted (and I don't need to delete twice)?
Hi all,
I store DNG on CFe and JPG on SD. How can I set my SL3 in a way that I am only looking and deleting DNG files and not also having to look at (identical) JPG's while going through my pictures on the screen and how to avoid I have to delete also the JPG files when I delete the DNG file.
I store JPG's only because I can more easily send them to others using my iPhone but for my photography I only want to look, select and delete DNG's and have the JPG's stored/deleted in the background.
Is that possible?
Rgds,
Maikel
The Netherlands
1 hour ago, Maikel said:
Hi all,
Is that possible?
Rgds,
Maikel
The Netherlands
It is in general not a good idea to delete images in the camera. This is best done in the computer.
You can simply format the SD card in-camera and all JPGs will be gone.  If you store the DNG and JPG on the same card, deleting the image will delete both DNG and JPG.  I prefer this as I set the camera to store to both cards simultaneously to have an automatic backup. Then I upload one of the cards in the computer in Bridge and rate and sort/delete the images. Mostly I keep nearly everything - you never know for the future and storage is cheap.
The Fotos app give you the option to copy only JPG. not sure it is necessary to have it on a separate card.
Actually, I agree. It has no additional value to do so. Writing to two cards does have advantages like getting an instant backup or extending storage, but I see no addd value here.
