arrigato Posted July 9, 2024 Share #1 Â Posted July 9, 2024 Advertisement (gone after registration) Not sure if this is the right section for this, but here goes. Â I have a M5 that I assumed was not converted to take the 1.5 volt batteries. Â So, I bought a CRIS adapter and everything works fine as far as I can tell. Â However, the needle for the battery check doesn't get into the notch in the viewfinder. Â It only goes about two thirds of the way there. Â If I were to put in a 1.5 volt battery without the adapter, would this do any harm. Â Thanks for any help. Link to post Share on other sites More sharing options...
Advertisement Posted July 9, 2024 Posted July 9, 2024 Hi arrigato, Take a look here M5 Battery. I'm sure you'll find what you were looking for!
TomB_tx Posted July 9, 2024 Share #2 Â Posted July 9, 2024 1.5 won't cause harm. Sounds like maybe the meter was adjusted for 1.5 - worth a try. Link to post Share on other sites More sharing options...
arrigato Posted July 21, 2024 Author Share #3 Â Posted July 21, 2024 Thanks for the info. Â Link to post Share on other sites More sharing options...
