hellobrandonscott Posted July 9, 2024 Author Share #21 Posted July 9, 2024 Advertisement (gone after registration) 13 hours ago, serhan said: You can 3D-print 6-bit code template and mark it yourself: https://www.fredmiranda.com/forum/topic/1855867/ Does the paint wear off since the 6-bit portion wouldn't be recessed like it is on actual 6-bit lenses? Link to post Share on other sites More sharing options...
Advertisement Posted July 9, 2024 Posted July 9, 2024 Hi hellobrandonscott, Take a look here Is $250 worth getting a lens 6-bit coded? . I'm sure you'll find what you were looking for!
BernardC Posted July 9, 2024 Share #22 Posted July 9, 2024 7 minutes ago, hellobrandonscott said: Do I want this calibrated for digital if I plan on occasionally using it with an MP? I think that Leica tightened their standard because digital sensors are absolutely flat (film can bow a little bit), but the new standard works for both film and digital. 1 Link to post Share on other sites More sharing options...
MikeW Posted July 9, 2024 Share #23 Posted July 9, 2024 19 hours ago, serhan said: You can 3D-print 6-bit code template and mark it yourself: https://www.fredmiranda.com/forum/topic/1855867/ or I've done this; in Vancouver a 3D printing shop I reached out to, 10 minute walk from me, created the jig for 20$ CAD. Some US Fred Miranda folks reported < 10$. uni POSCA black and white 0.7mm tip pens designed for glass and steel did the job on a Voigtlander 28mm Ultron, which conveniently has a small recessed groove that neatly holds encodings so they don't rub off under use. I'd consider getting it done by a Leica tech if I had an older Leica lens that also needed servicing. Link to post Share on other sites More sharing options...
