If they seem to work well on film camera's that indicates they are not far out of calibration. It is hard to compare but depending on the film used, resolution of film is between 8 and 20 MP.  this means that maybe you never noticed the differences on film because of the lower resolution.
Did you do a test on tripod with careful manual focus, and compare that with the optimum focus using LV and magnification focus aid?
Compare all three lenses this way and at different apertures.
The Summilux 35 pre-ASPH was known for its focus shift issues. So even if you focus correctly in the RF, it will be slightly off in a certain direction depending on the chosen aperture. This cannot be fixed by calibration, it is inherent to the design of this lens. The Summicron's are not known to have this issue.
I am not sure if the re-issue of the 35 Summilux has the same issues, but it seems probable.
