I’m booked to participate in a sanctioned two-hour photography tour of closed interiors of the landmark former Buffalo State Hospital (1870s-1990s) designed by H.H.R. Richardson and Frederick Law Olmsted. The tour will run from 6:00-8:00PM. It is geared specifically to photographers and tripods are allowed, so I’d think some allowances will be made to setup, compose, execute shots but I could see some challenges with time and people getting in the way.
What advice or tips do those experienced shooting abandoned interiors having had shot with digital Leicas?
I plan on taking the following:
- SL2-S with a Vario-Elmarit 24-70 on an RRS bracket
- M10R with Voigtlander 21mm f1.4
-M10-P with Summilux 50mm f1.4
- Sirui A-1205 c-f travel tripod
I will have an assistant to help me manage equipment, water, etc.
I’m thinking of setting up a profile for bracketing SL2-S and M10R exposures on the tripod (so IBIS off the former) - would one full stop over/under metered reading (3 shots) be enough to protect highlights and capture shadow detail or is more better? Should I use exposure compensation (-EV) when bracketing or use that only on single shots? I imagine I’d mainly be hand-holding any given camera as I go, then set up with the tripod on shots where I want maximum depth of field and detail.
I also have an M-to-L adapter so could put the 21mm on the SL2-S if 24mm isn’t wide enough, but wouldn’t want to if the interior is too dusty
Thanks for any thoughts or lessons you’ve learned in similar settings.
Ken
Edited by theseahawk
I see that you can use one of the legs of this tripod as a monopod setup. A monopod will bring both a bit stability and speed, compared to setting up a full tripod.
If you have a separate monopod, even better.
Bring the monopod too, then you can see what works best on location.
Thanks, great advice. I do have a separate monopod so may ready that to use with the M cameras.
Would you use negative EV to protect highlights even when bracketing? Or weight the bracketing towards underexposure?
Wonderful suggestions by everyone, I would encourage a going deep within yourself to the unchartered territories of your own darkness …imagery that tells a story, feel the whispers of those that were in there….shoot from your well of knowing, don’t let equipment get in the way, look for unusual perspectives…
