yujh Posted May 17, 2024 Share #1  Posted May 17, 2024 Advertisement (gone after registration) Hello! I have a Leica M-A and a SF C1 remote control unit with the SF60. It is successfully paired and it works when the SF60 is in the A position - I can manually control its output level using the "M" mode on the SF C1 unit. The flash works great... however, the front facing Red AF Assist Light won't stop blinking! I've looked online an there is no mention of how to disable this flashing light (other than gaffer's tape). If I set the SF60 to "M" mode, the light stops blinking, but that completely eliminates my ability to control the output level using the SF C1. The digital M cameras have menu features to turn off the AF Assist Light via the menu (i.e., Q3, M-11), but is there a way to do this inherently with the SF60 so I can use it discretely in wireless, handheld mode? Any help is greatly appreciated! Link to post Share on other sites More sharing options...
Advertisement Posted May 17, 2024 Posted May 17, 2024 Hi yujh, Take a look here Film M-A Camera with SF C1 remote control unit paired with SF60 Flash - Red AF Assist Light won't stop blinking!. I'm sure you'll find what you were looking for!
Biotar Posted May 17, 2024 Share #2 Â Posted May 17, 2024 wich A-Postion u mean ... A-Mode or A-Group? Link to post Share on other sites More sharing options...
yujh Posted May 17, 2024 Author Share #3 Â Posted May 17, 2024 "A" group... there are "A", "B", and "C" settings for the wireless channels. Thank you! Link to post Share on other sites More sharing options...
Fotoklaus Posted May 18, 2024 Share #4 Â Posted May 18, 2024 I think the SF60 will only work in TTL-Mode on cameras wich Support this. The M-A has just a simple X-Synch Contact. Link to post Share on other sites More sharing options...
250swb Posted May 18, 2024 Share #5 Â Posted May 18, 2024 What do I know but maybe the AF on your M-A is broken? 3 Link to post Share on other sites More sharing options...
Joasop Posted February 14 Share #6 Â Posted February 14 Hello. I have the same issue and I don't see anything in the manual about it. It might have something to do with the connection to the SF C1. When I switch it to other settings than that of A, B, or C on the flash then the red flashing light goes away. Have you found a solution to this? Link to post Share on other sites More sharing options...
yujh Posted March 21 Author Share #7  Posted March 21 Advertisement (gone after registration) I did find more information! I spoke with the amazing staff at the Leica Store (Meatpacking New York) and they indicated that the red flashing light on the flash indicates a wireless connection to the SF C1 hot shoe module is active. Unfortunately, there is no way to disable the flash from blinking red when used wirelessly. I hope this info helps!  Link to post Share on other sites More sharing options...
