I have an old Leitz ballhead with a mangled 1/4" male screw, which does not look pretty but mounts to a camera OK. This is in the picture with the screw pointing up.
The other picture (screw pointing down) shows an apparently un-mangled equivalent with what looks like a larger 3/8" mount, surrounding (I'm guessing) a 1/4" mount.
Was it the case that older Leicas not made for export had a 3/8" mount, and therefore older ballheads were made like in the latter example, such that they could be used with either 1/4" or 3/8" camera mounts?
If so, was the 3/8" sleeve intended to be easily removable from the 1/4" mount inside?
Thanks in advance to anyone who can clear this up for me.
Hi Johnson,
On my old Leitz ball head I can unscrew the top plate and simply turn the screw mount upside down to switch between the different sizes, if so remember correctly
… can check tonight, if that would help
Cheers
Tim
Some of these Leitz heads have a clever coaxial screw design where a  3/8" sleeve can extend or retract around a central 1/4" screw. Sometimes these can become jammed if there is corrosion or damage etc.
Others, like mine, have a reversible disc that can be screwed on with either the 1/4" or 3/8" screw facing up, and perhaps there are also heads that only have one type of screw; these things were made in several variations over many years.
Hi again Tim,
Inspired by your comment, I had another go at the screw on the side of the head component. With this out, with some force I was able to unscrew the whole head component (it appeared to be held by some sort of threadlocker gunk) which revealed a spring loaded mechanism.
It now seems that the 3/8 sleeve on the head is intended to be simply pushed down to reveal the 1/4 mount. There is even a keyway inside the head to prevent the sleeve from twisting. What a great pice of engineering and so well made. Similarly the baseplate has a spring-loaded mechanism to work with either a 1/4 or 2/3 tripod mount.
It's just a shame that the previous owner of mine didn't seem to know this and instead hacked off the 3/8 sleeve and in the process also badly damaged the 1/4 inch mount.
I once spent hours trying to remove the 3/8 sleeve on my Leica ball head, only finally to discover that it just pushed down (Doh!). My Leica earlier ball head has a reversible mount with 1/4 one side and 3/8 the other, held in place by a knurled sleeve.
Wilson
