bobtodrick Posted May 3, 2024 Share #21 Posted May 3, 2024 Advertisement (gone after registration) 1 hour ago, David Wien said: I still dont see noise. Try doing it at ISO 12500 and you will see some noise (which can be removed by PhotoLab, etc), but at ISO 800 my Q3 is free of noise. David Same here…I would have thought they were the same photo because I don’t see any noise. Link to post Share on other sites More sharing options...
Advertisement Posted May 3, 2024 Posted May 3, 2024 Hi bobtodrick, Take a look here Noisy Jpegs. I'm sure you'll find what you were looking for!
David Wien Posted May 3, 2024 Share #22 Posted May 3, 2024 44 minutes ago, bobtodrick said: Same here…I would have thought they were the same photo because I don’t see any noise. No. The camera has been moved laterally between the two shots. David Link to post Share on other sites More sharing options...
Kozonoh Posted May 3, 2024 Author Share #23 Posted May 3, 2024 Even if you don’t see noise it is a bit puzzling that you don’t see the difference due to the alteration of the in-camera jpeg compression. But then… Link to post Share on other sites More sharing options...
David Wien Posted May 3, 2024 Share #24 Posted May 3, 2024 The artifacts of the camera generated jpeg are definitely worse -- probably due to the fact that there is less processing power available. "My L-jpeg files which should be at 60 m are only at 30 m without any cropping in camera. My Film Style settings are set to std, noise reduction high, idr off. What am I missing? " Try setting noise reduction to low. You should need no noise reduction at ISO 800 with the Q3. What do you mean by 60/30 m -- MPixels? The size of a jpeg depends upon the complexity of the image. If you save the raw file to jpeg and compare it with the out of camera jpeg of the same linear dimensions (9520 x 6336 in each case) you can then compare the filesizes of the two. Whichever is smaller has had the most compression in converting to jpeg. David Link to post Share on other sites More sharing options...
Kozonoh Posted May 4, 2024 Author Share #25 Posted May 4, 2024 Thank you David for your answer. You are right. I checked the in-camera Jpg in dxo and applied High Quality noise reduction (prime not available for Jpgs) without seeing any difference so it is only the compression which is responsible. But still I found the level of loss very high. Vive le Raw. Link to post Share on other sites More sharing options...
David Wien Posted May 4, 2024 Share #26 Posted May 4, 2024 I am glad that problem has been solved! 😃 David Link to post Share on other sites More sharing options...
