Davidsosa Posted April 21, 2024 Share #1  Posted April 21, 2024 (edited) Advertisement (gone after registration) Hi guys! A couple of months ago I bought this m6 TTL. After using it for a bit I realised that the viewfinder that this fog/haze.barely visible with the naked eye. But showed clearly when I put a light on the back.  I sent it back to the seller and he took it to hi tech. But came back looking the same. The Tech said it’s on the actual glass and couldn’t be cleaned.  Should I be worried of it getting worse?  what can it be?  thank you so much! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited April 21, 2024 by Davidsosa Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/393247-hazy-viewfinder/?do=findComment&comment=5205635'>More sharing options...
Advertisement Posted April 21, 2024 Posted April 21, 2024 Hi Davidsosa, Take a look here Hazy viewfinder. I'm sure you'll find what you were looking for!
hansvons Posted April 21, 2024 Share #2  Posted April 21, 2024 Does it bother you while focusing? If not, I’d stop thinking about it. If it still bothers you, have the optical system upgraded. That's costly but you’lm be ending up with a camera that's unique. Link to post Share on other sites More sharing options...
Anbaric Posted April 22, 2024 Share #3 Â Posted April 22, 2024 (edited) I wonder what the technician actually tried? If they weren't a Leica specialist they might have made the wrong assumption, or just not bothered to attempt cleaning. I think VF haze can usually be cleaned unless fungus has etched the glass, which would require a new window to fix. If it bothers you, you should probably get a second opinion. If it doesn't affect your use of the camera, it might be better to leave it alone. Edited April 22, 2024 by Anbaric 1 Link to post Share on other sites More sharing options...
250swb Posted April 22, 2024 Share #4 Â Posted April 22, 2024 It looks to me like the sort of bloom you get when oil or grease evaporates or perhaps if the camera had condensation inside (easy to happen on a damp humid day). If it is it should be easy to clean after the top plate is removed. Link to post Share on other sites More sharing options...
Davidsosa Posted April 22, 2024 Author Share #5  Posted April 22, 2024 13 hours ago, Anbaric said: I wonder what the technician actually tried? If they weren't a Leica specialist they might have made the wrong assumption, or just not bothered to attempt cleaning. I think VF haze can usually be cleaned unless fungus has etched the glass, which would require a new window to fix. If it bothers you, you should probably get a second opinion. If it doesn't affect your use of the camera, it might be better to leave it alone. Yeah. I don’t know the technician, and whether he tried to fix it or not. Is strange as it doesn’t look like fungus.  might try to keep using it as is. Sometimes in certain scenarios it makes focusing a bit more difficult. But can’t afford to take it to Leica at the moment. Link to post Share on other sites More sharing options...
spydrxx Posted April 23, 2024 Share #6 Â Posted April 23, 2024 I'd take it to a trained Leica technician (don't know where you live). Even if it is water or grease evaporation, I'd get it either cleaned or have the glass repaired. Personally I can live with minor issues and inconveniences, but having clear focusing is a must in my book. YMMV 1 Link to post Share on other sites More sharing options...
Davidsosa Posted April 27, 2024 Author Share #7  Posted April 27, 2024 Advertisement (gone after registration) On 4/23/2024 at 9:12 PM, spydrxx said: I'd take it to a trained Leica technician (don't know where you live). Even if it is water or grease evaporation, I'd get it either cleaned or have the glass repaired. Personally I can live with minor issues and inconveniences, but having clear focusing is a must in my book. YMMV Yeah. The seller is a well known Leica seller and he took it to his technician. He told me it’s etched in the glass. But it’s a weird thing as it doesn’t seem like a fungus problem.  might try to find a second opinion.  im in Australia. Link to post Share on other sites More sharing options...
