Photoworks Posted May 31, 2024 Share #41 Posted May 31, 2024 Advertisement (gone after registration) 11 hours ago, vhsin964 said: I can nor charge BP-SCL6 by Nitecore recharger. Why? i have been using it all the time Link to post Share on other sites More sharing options...
Advertisement Posted May 31, 2024 Posted May 31, 2024 Hi Photoworks, Take a look here SL3 battery charger question . I'm sure you'll find what you were looking for!
vhsin964 Posted June 1, 2024 Share #42 Posted June 1, 2024 1 hour ago, Photoworks said: Why? i have been using it all the time My Nitecore recharger works for BP-SCL4 only. All my 3 BP-SCL6 not work. Link to post Share on other sites More sharing options...
Chuck Albertson Posted June 1, 2024 Share #43 Posted June 1, 2024 17 hours ago, Carrot said: I’ve found that if I put a ‘4’ and ‘6’ battery in the charger together, only the ‘6’ charges. The ‘4’ will only charge if I remove the ‘6’. Mine handles both types at the same time. The newer batt takes a little longer, but that's to be expected. Link to post Share on other sites More sharing options...
algrove Posted June 1, 2024 Share #44 Posted June 1, 2024 On 4/2/2024 at 2:06 AM, SrMi said: Are you sure the new battery (BP-SCL6) does not work with the old charger? After all, Q3 is being shipped with the new battery and the old charger, and I am confident I was charging BP-SCL6 with the old charger. Agree, I charge new batteries in old chargers all the time. It just takes forever to fill the charge versus the newer chargers. That said expect a long charge time with the new batteries in any charger. Link to post Share on other sites More sharing options...
Jptsr1 Posted June 11, 2024 Share #45 Posted June 11, 2024 (edited) On 5/31/2024 at 4:02 PM, Carrot said: I’ve found that if I put a ‘4’ and ‘6’ battery in the charger together, only the ‘6’ charges. The ‘4’ will only charge if I remove the ‘6’. Just tried this and it worked fine. I wonder if your brick isn't supplying enough power to charge them together? I could see the charger waiting for one to be charged first in that instance. Like a charger for drone batteries. Edited June 11, 2024 by Jptsr1 spelling Link to post Share on other sites More sharing options...
