geesbert Posted March 16, 2024 Share #1 Posted March 16, 2024 Advertisement (gone after registration) In my 25 year career as a food photographer I switched camera systems many times, started with Canon EF, then Leaf, then Phase One, then Sony, then Fuji GFX and lastly Canon RF. But all of the time I used Canon's fabulous TSE EF Lenses. They can be made to work with nearly everything. Is anyone around here using them with Leica SL cameras? As I see there are only two viable EF adapters, the Sigma mc-21 and the Viltrox Pro. Will they work? Link to post Share on other sites More sharing options...
Advertisement Posted March 16, 2024 Posted March 16, 2024 Hi geesbert, Take a look here Any SL owners using Canon's TSE lenses? . I'm sure you'll find what you were looking for!
BernardC Posted March 16, 2024 Share #2 Posted March 16, 2024 Definitely the Sigma adapter. Sigma are L-mount partners, they aren't reverse-engineering the interface. Several people have reported that they use Canon's tilt-shift lenses on L-mount cameras, but I'm not sure if someone has mentioned the SL3 yet. They have with other EOS lenses, so it's unlikely to be incompatible. TS-E lenses are some of the easiest EOS lenses to support, since they don't have AF or OIS. All the camera has to do is read/actuate the aperture. Link to post Share on other sites More sharing options...
Photoworks Posted March 16, 2024 Share #3 Posted March 16, 2024 I have been using the Sigma MC21 for 4 years with TS-E lens for the architectural / interior on the SL2, I have done one shoot with them on the SL3 and they worked the same. not sure if I would trust the Vitrox adapter, it is not a partner. I have found that the Canon TS-E lenses work better on the Leica than many other systems like Sony. The microlens sensor cover glass on Sl2/3 to get M lenses to perform well on SL cameras, make it possible to remove smearing from corners even on the Canon lenses. 1 2 Link to post Share on other sites More sharing options...
dkCambridgeshire Posted March 16, 2024 Share #4 Posted March 16, 2024 i use the original Novoflex SL/EOS adapter with various Canon TSE lenses on my SL 601; this adapter is not compatible with the SL2 series and SL3. Lens aperture is thus controlled by the camera. The Novoflex adapter is not suitable for EOS AF lenses but for manual focus EOS lenses it's fine. Link to post Share on other sites More sharing options...
lx1713 Posted March 20, 2024 Share #5 Posted March 20, 2024 On 3/17/2024 at 12:16 AM, Photoworks said: I have been using the Sigma MC21 for 4 years with TS-E lens for the architectural / interior on the SL2, I have done one shoot with them on the SL3 and they worked the same. not sure if I would trust the Vitrox adapter, it is not a partner. I have found that the Canon TS-E lenses work better on the Leica than many other systems like Sony. The microlens sensor cover glass on Sl2/3 to get M lenses to perform well on SL cameras, make it possible to remove smearing from corners even on the Canon lenses. likewise. I've the 17mm and the 90mm TSE on the Sigma MC21 but I don't use these lenses much. Very good lenses. I didn't compare them to my Apo summicrons though as I don't use them for the same purposes. Link to post Share on other sites More sharing options...
georgecp Posted March 20, 2024 Share #6 Posted March 20, 2024 I have been using my 3 Canon TS-E lenses, 24mm, 50mm, 90mm with the sigma adapter on an SL2 and S1R for several years with great results. Link to post Share on other sites More sharing options...
robb Posted March 21, 2024 Share #7 Posted March 21, 2024 Advertisement (gone after registration) Great results with 17 and 24 tilt shifts with the sigma adapter even in multishot mode. Normally shot at f8. i have used the 50 tilt shift in the past and thought it was optically even better. Robb Link to post Share on other sites More sharing options...
geesbert Posted March 21, 2024 Author Share #8 Posted March 21, 2024 just received my mc21. as said above works with my TSEs. I tried it with my only remaining EF AF lens, the Sigma 1,4 50mm ART. it is sooooo slow... Link to post Share on other sites More sharing options...
Photoworks Posted March 21, 2024 Share #9 Posted March 21, 2024 4 hours ago, geesbert said: just received my mc21. as said above works with my TSEs. I tried it with my only remaining EF AF lens, the Sigma 1,4 50mm ART. it is sooooo slow... Yes, it is slower, I should try the SL3 and see if it is any better. But I think your problem is that the lens you are using is an older design for DSLR. Is it? Link to post Share on other sites More sharing options...
