Has anyone noticed that the AWB takes a long time to stabilize with different lighting conditions on the SL3?  Even if I use different parts of the same room with different warmth of lighting in different areas I need to wait a bit for everything to lock in.  My SL2-S is much faster in this regard.
  • 1 month later...
I have no experience with the SL3. but I find the m11 under certain lighting conditions reacts to quickly. LED lighting for instance, which is constant will give different results from frame to frame, whereas using a gray card to fix a balance doesn't. So, perhaps if it does its an intentional effort to improve on the m11
